Offline Jay
#1 Posted : 27 May 2021 16:03:48(UTC)
Jay
I have a MS 1 controller together with a section of C track that has a connection for the MS 1 cable, a power
supply cable and 1 other 7 pin female socket for what I can describe as a DIN plug of old. I have tried a search
of previous topics to no avail.
My questions
1) Can someone help me with were I could download a MS 1 manual?
2) How can I connect the MS 1 directly to the M track as I do not have the transition pieces from C to M track
and do not have a dealer anymore in this town.
I will be grateful for any help in this regard.
Warm regards
Jay
thanks 1 user liked this useful post by Jay
#2 Posted : 27 May 2021 16:21:15(UTC)
MS 1 manuals can be found here:
https://www.maerklin.de/...e/details/article/60652/
The track connector 60115 is for K Track, but can also be used with M Track.
You can unscrew the "ugly box" from the 24088 feeder track and connect the spade connectors to your M Track. Or cut the spade connectors off and mount regular banana plugs. Or solder wires. No need to get a transition track.
You can connect two MS1s and a power supply to the feeder track. An adapter cable is required for the slave MS1.
Offline Jay
#3 Posted : 27 May 2021 16:56:17(UTC)
Jay
Hi Tom,
Thank you for the quick and useful reply.
I forgot to mention that I also have another grey box 60113.
This also like the "ugly box" has 3 connections. Is it similar to the 60115 that you mention?
Thank you for your help
So appreciated
Best
Jay
#4 Posted : 27 May 2021 17:16:57(UTC)
The 60113 is for the MS2 and cannot be used with the MS1.
This page was generated in 0.387 seconds.
