Offline GMDolan
#1 Posted : 20 May 2021 06:23:43(UTC)
GMDolan
Has anyone had success in powering 74491 switch motors with DC? Details please.
Offline PeFu
#2 Posted : 20 May 2021 07:41:28(UTC)
PeFu
Yep, have a look here:
https://www.marklin-user...itching-problem---Solved
I’m now powering all switches, incl. those having 74491 motors, using 20V DC.
Smile
Offline GMDolan
#3 Posted : 20 May 2021 16:40:40(UTC)
GMDolan
Thanks for the quick response to my inquiry. Have you measured the current draw at 20VDC?
I plan on testing 15 to 24 VDC. With success I'm likely to build custom PCBs to power my turnouts. I want to investigate DCC++EX control software to see how best to integrate turnout and signal control with that software ecosystem.
#4 Posted : 21 May 2021 00:34:59(UTC)
Measuring the current is difficult with a multi-meter because the pulse duration needs to be very very short (100mS or so) so only using a resistor and an oscilloscope.
Working with DC, calculating the current is easy: measure the coil resistance (the only factor to limit the current in DC operation). Then I=U/R (as we all know)
Märklin decoders like the 6083, 60832 work in hashed DC voltage (19 V DC) so the difference is that the coil inductance comes additional to its resistance to reduce the current.
I would not advise operation above 20 V DC because, on a good solenoid the force is already ample enough. Yes you may get more force but increasing the voltage (25 VDC) and logically reducing the duration (50mS) but it would produce a force and a shock for which the Märklin switches were not designed for (You will destroy them).
Note: Märklin is aware of this trend to short-circuit the protection switches as they have reduced the minimum duration on CS2 and CS3 to 100 mS (it was 200 mS a few years back) which is ample enough to have a very reliable operation.
#5 Posted : 21 May 2021 06:52:30(UTC)
I use 24Vdc. I have programmed my system to activate the pulse for 0,1s.
I give each movement 2 pulses(!), as sometimes the switching is so hard that the mechanism seems to bounce back a little. The 2nd pulse leaves the relay in its right place.
I thought I would be having a magnetisation problem in the long run, but after 15 years this doesn't seem to be a problem. (I´m using K-track switch motors, both old and new)
This page was generated in 0.405 seconds.
