#1 Posted : 21 April 2021 14:46:03(UTC)
Hi, my former dealer installed one in my 3511 back in the late 90's or early 2000's. It runs well, slight low buzz at low speed, goes away with higher speeds. I don't run her that much. I read on here by webmasterCrying that a c90 decoder will fry a Faulhaber motor. Is this deocder one?
Thank's in advance.
#2 Posted : 21 April 2021 15:01:50(UTC)
no it will not, may be a little grease to the worm gear
#3 Posted : 21 April 2021 15:07:38(UTC)
Märklin offered the 60905 decoder for the Faulhaber motors.
I don't know if the 60902 can be harmful to Faulhaber motors, but there must be some drawbacks, otherwise Märklin would not have made the 60905.
"c90" stands for the 6090 decoder.
#4 Posted : 21 April 2021 15:14:15(UTC)
Ok, thanks Tom! Dave was very good with electronics. If the 60905 had been out yet, he'd have put one in it. He was a former TV-hi-fi repair specialist. He added hobbies when solid state eliminated much of his business. He used an Intellibox back then, etc.
#5 Posted : 21 April 2021 15:23:43(UTC)
"I read on here by webmasterCrying that a c90 decoder will fry a Faulhaber motor. Is this deocder one?
Thank's in advance."
I made a try long time ago on the 3611 I have. You will not fry it but the speed curve will be "disappointing" (no slow speed).
This is because the rotor coils have no iron core so a totally unusual inductance value. This is a Glockeankermotor. The best there is but needs an adapted drive decoder.
A mLD3 or mSD3 (with Sound- 60975 for steam sounds) will allow to enter the motor type (CV52 = 4 for Bell armature / Glockenanker)
Then you can run the auto calibration using CV7
You must have selected the proper motor type beforehand
You must install the loco on a large diameter loop (it will go full speed for a moment)
Then write 77 into CV7
The loco will start slowly and faster possibly start and stop
After a while the auto calibration is finished
#6 Posted : 21 April 2021 15:51:47(UTC)
BigGrin
He must have added a diode or resistor or something then, because I have great slow speed. I'll have a look beneath the decoder.
#7 Posted : 21 April 2021 17:54:42(UTC)
BigGrin
It creeps smoothly on speed step 1 on the CS3, towing 4 cars. There is a small board not original with only a single black/yellow/orange resistor under the decoder. Not sure if it's only for the led's.
#8 Posted : 21 April 2021 18:41:38(UTC)
A standard old 6090 will eventually fry the Faulhaber motor, due to its low frequency pulse rate on the motor drive that makes the motor coil basket rattle & vibrate more than healthy.
The 60902 is not a 6090. It is newer... Smile
There was eg 3711 Wuerttenberg C (and 37112 "Olympia") that was announced as 6090, but it had a special board with rectifiers and no EMF feedback for load control.
One of the first decoders that could have a higher frequency motor output was the LokPilot/Loksound decoder that could be set to 20KHz (or something like that) frequency for the motor feed.
The mfx decoders from M do have a high frequency motor output, as well as many other also have. The mSD versions are easily programmable too, as JohnJeanB says.
#9 Posted : 21 April 2021 21:01:33(UTC)
BigGrin
Thank you Johan! I wish my old dealer hadn't reired and closed. He was also knowledgable. I have a 37537 br 120 from 2004, with an 8 pin plug in decoder. No part number, no dip switches. It runs excellent, but the only sound function, a far distant low volume horn or whistle, and volume is not adjustable with a control unit. I'm curious if there is a plug in newer decoder with more sounds that can plug in without gutting the led board it plugs into. that part is 225 205. The speaker is a large round frame mounted 508 607.
This page was generated in 0.606 seconds.
