Offline fynrfin
#1 Posted : 15 March 2021 22:29:48(UTC)
fynrfin
I have been reading up on the posts about the old 220V transformers and their too high output.
When last I ran my layout I used an old Marklin trafo for digital, it has two yellow-brown outputs (it is 220 Volts so I use a transformer to change 110V coming out of my mains) - I measured the output as about 18V AC
I checked an old 110 V marklin transformer, the output was also 18V AC.
HOWEVER, the input on my Intellibox says 16V. So is the 18 V AC too much for it?
I think this is the setup I used last time things ran without problems, but I got worried reading about the excess output of 220 V trafos.
Thank you for your help
Steen Jorgensen
#2 Posted : 16 March 2021 02:23:03(UTC)
The nominal mains voltage increased from 220 to 240 and 110 to 120 - about 10% that is why what used to produce 16VAC now produces about 18VAC
I know this does not answer the exact question about if the IB can handle the extra 10%. I suspect it would, only because I think we would have heard many sad stories about them frying at 18VAC.
#3 Posted : 16 March 2021 08:08:01(UTC)
The nominal mains voltage increased from 220 to 230 Volts - about 5% more.
Märklin make a big fuss about this small increase because they went cheap with their 2005 decoder generation. But the real problem about the decoder weakness is the reversing voltage which is extra high on old blue metal transformers.
The IB manual allows up to 18 V input voltage.
Once again this is the nominal voltage. Transformers reach their nominal output voltage with the nominal load, so slightly higher voltages when idle are also OK.
No problem if your transformer gives 18 V without load.
This page was generated in 0.252 seconds.
