Offline 1borna
#1 Posted : 08 March 2021 21:05:19(UTC)
1borna
Croatia
Back in the mid-70s, my friend Darko started making a larger layout in the basement
This is how it started with a size of 500 x 200 cm
Later a station was added above the back which then became hidden
2012 his cousin ing.Makanec invited me to help him enable the layout because for the last 5 years there was no one to drive it (I'm left)
A young friend also helped us because the whole track needed to be cleaned well
The layout, meanwhile, spread to the other side of the room
and eventually through the wall the railroad ended up in another room
My friend Darko has had problems with being overweight all his life so he has been almost immobile for the last 10 years
Last year he came to his last station ...
thanks 22 users liked this useful post by 1borna
#2 Posted : 09 March 2021 00:42:23(UTC)
looks like 45 years of train fun for him. I hope it made his life better.
Offline 1borna
#3 Posted : 12 March 2021 22:09:34(UTC)
1borna
Croatia
Darko was visited and helped by several friends in making the layout, some of them are also no longer alive
I will try to conjure up a layout with more photos
The large depot for diesel and electric locomotives had 2 drawbridges
UserPostedImageUserPostedImageUserPostedImage
On the other side is a turnaround with a depot for steam locomotives
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
thanks 12 users liked this useful post by 1borna
Offline BR23
#4 Posted : 13 March 2021 03:13:21(UTC)
BR23
What an amazing layout! Thanks for sharing Darko's wonderful railroad!
Ricky
Enjoying Marklin HO trains since 1964.
thanks 1 user liked this useful post by BR23
Offline 1borna
#5 Posted : 13 March 2021 08:26:08(UTC)
1borna
Croatia
Thank you!
Some modelers resented it for being a large marshalling yard with too little relief but it was his choice. Someone else could make one big city with a little track around or a big mountain massif, after all our layouts are thank God different!
thanks 2 users liked this useful post by 1borna
Offline 1borna
#6 Posted : 19 March 2021 20:50:13(UTC)
1borna
Croatia
In the middle is a small circle of Faller AMS cars
There is also a train parking space
The station is only with platforms, the building is located more to the left in the middle
Upstairs is a smaller station
thanks 10 users liked this useful post by 1borna
Offline 1borna
#7 Posted : 29 March 2021 21:02:58(UTC)
1borna
Croatia
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
thanks 11 users liked this useful post by 1borna
Offline 1borna
#8 Posted : 11 April 2021 21:55:48(UTC)
1borna
Croatia
There was a small work area in the other room
Here you can see the moving part at the door of the first room
At the lower level is one small end station
Shelves for models are made on several walls
thanks 6 users liked this useful post by 1borna
Offline ocram63_uk
#9 Posted : 13 April 2021 17:24:11(UTC)
ocram63_uk
Hi, I can see that these pictures are from 2012 / 2013 we are now in 2021. What happend to the layout ? Is it stil working and people enjoy it or it is a massive piece of rust since the owner isn't around anymore ? Thank you
Offline 1borna
#10 Posted : 13 April 2021 18:50:24(UTC)
1borna
Croatia
Unfortunately it all ended sadly!
Due to his real estate, Darko could not enter the basement, which was not his property. Since the real owner intended to sell the entire basement I had to dismantle everything before a few years and Darko died late last year.
First I removed the part that goes along the wall to the other room and then everything in another room
There are still some photos from happier times left for the second time
Offline ocram63_uk
#11 Posted : 14 April 2021 11:55:37(UTC)
ocram63_uk
What a sad ending 😢
thanks 3 users liked this useful post by ocram63_uk
#12 Posted : 14 April 2021 13:47:37(UTC)
Life is short. Make each day count! We take nothing with us. Every posession is a borrowed item. Care for them, and leave them to others who will appreciate them.
thanks 4 users liked this useful post by marklinist5999
Offline 1borna
#13 Posted : 25 April 2021 21:06:51(UTC)
1borna
Croatia
The control was analog from the beginning, and later the possibility of dialing for digital was added
The power supply went by rail or catenary, each could be different
Control of signals, switches and others was the only analog, this is an earlier performance
Later performance with a better keyboard
There was also an overflow field (blue) on which it was chosen which would initiate some contact on the track (initially the counter-rails which were later replaced by reed)
The control panel for the layout in the other room was made much later
thanks 4 users liked this useful post by 1borna
Offline 1borna
#14 Posted : 06 May 2021 22:06:21(UTC)
1borna
Croatia
A little display of technique, the place where the wires came and connected to the counter
Initially, old relays from the telephone exchange were used, later newer ones came
UserPostedImageUnderground layout in another room
In the beginning, everything was neatly wired, later a little mess was made by adding it
thanks 5 users liked this useful post by 1borna
Guest (4)
This page was generated in 0.619 seconds.
