Offline danmarklinman
#1 Posted : 07 February 2021 12:31:07(UTC)
danmarklinman
Hi, can anyone tell me if acme and lsmodels coaches run on 36 radius curves, I have one or two areas on my layout were I really don’t want to re build. Is it just there length that’s the problem or there bogie pivot points?
Thanks Dan
Wiking model car Fan
Instagram: marklin1978
Wiking fan
#2 Posted : 07 February 2021 18:35:08(UTC)
The instruction manual that comes with each model usually lists it's minimum recommended radius.
Most 303mm coach models can run on minimum R2 curves. Some models can run on R1 (360mm) radii, although certain parts may interfere with the bogie rotation and the overhang of the coach might interfere with signals, catenary masts and tunnel entrances. Check with your supplier before ordering.
This page was generated in 0.202 seconds.
