Offline crow79
#1 Posted : 29 January 2021 09:03:45(UTC)
crow79
Hi There, I m very new on this.
I have a small H0 rail with a mobile station 2 and I bought a Locomotive on Ebay with an ESU LokPilot 3 DDC, but I don't know how to get it work.
The seller told me the adress is 2 but I tried to add this Locomotive on MM2 and DDC with adress to but it does not work.
This are the informations about the Lokpilot configuration:
00000097 (151)
0200002A
FFEBEEDD
Unrestricted
MultiDcc
How can I add this to my MS2 Control Unit?
Thanks.
#2 Posted : 29 January 2021 09:10:43(UTC)
Welcome to the forum!
Which software version do you have on your MS2 and your trackbox? Older versions are very buggy and can lead to problems.
Make sure DCC is enabled as a track protocol (this is the factory default).
Theoretically you only have to register the loco manually for DCC address 2. With only the new loco on the track you should then be able to set a new address or to read some CVs. The loco motor should make short moves while changing the address or reading CVs.
You can try different speed step settings (14, 28, 126) for the loco address.
This page was generated in 0.223 seconds.
