Offline Rinus
#1 Posted : 13 January 2021 11:10:22(UTC)
Rinus
Hi guys, I would appreciate some help.
I’m to install a different system for track detection. Now I’m using the uhlenbrock lissy system for track detection together with rocrail for automatic train control. The lissy system will sold and replaced by a S88 like system.
For those of you who have experience with this, how long should I make the section for track detection?
Some say one train lenght others say the length of an entire block section and others only 9 cm or so.
My rocrail design currently relies on 3 sensors per block in the visible areas and 2 in the hidden yards. I want to keep it that way if possible to ensure smooth transition.
Rinus
Edited by moderator 13 January 2021 23:58:39(UTC)  | Reason: Spelling
Offline French_Fabrice
#2 Posted : 13 January 2021 12:26:39(UTC)
French_Fabrice
Hello Rinus,
Just to be sure:
1- You are currently using Lissy system
2- You are going to replace it by S88 like system
Is it correct ?
Fabrice
Offline Rinus
#3 Posted : 13 January 2021 12:27:52(UTC)
Rinus
Hello Rinus,
Just to be sure:
Is it correct ?
Fabrice
Yes that is correct!
#4 Posted : 13 January 2021 12:45:34(UTC)
French_Fabrice
OK,
So please remind: The real concept to master is Block, not track occupation.
For automated trains using blocks, each block needs to have some sensor(s) in it.
As you already use Rocrail, you know about sensors which are associated with Events (like Enter, Pre2In, In events).
Another reminder: to manage blocks, an Event is fired only on the first occurrence of track detection occupation.
A feature introduced in Rocrail since a few years is BBT, which allow smooth deceleration in blocks.
When using BBT, 2 sensors are enough i.e. Sensor associated to Enter event and Sensor associated to In Event.
When a train has to slow down in a block with BBT, the slow down starts when the Enter event is triggered, until VMin is reached, then when In event is fired, the train goes from VMin to 0.
For such behavior, I think 9 cm for Enter sensor zone is enough, and depending on the inertia and CV settings, 18cm or 27cm is enough for In sensor zone.
Of course, this suppose the train has enough room to decelerate (the block is long enough) until reaching In sensor. But this depends also on the incoming speed at Enter sensor...
In case your block is bidirectional, then In and Enter sensor zones should have same length (18 or 27 cm)
A use case with a 3rd sensor (pre2in) in the block is for some station tracks where a "short train" have to stop not at the end of the block (In location) , but at the pre2in zone (close to the station or in the middle of the platform...)
That's a quick answer.
Fabrice
Offline Rinus
#5 Posted : 13 January 2021 13:30:11(UTC)
Rinus
Thx for your reaction! This is helpful.
Question: you say an event is fired only by first occurance of detection. Now would it be possible that in case of a short sensor zone of 9-27 cm that the event fired by the last wheel set of a 30cm coach behind the loco is seen as another train? If so this would make it more logical to me to use a 40cm section lenght as a minimum in order to keep the section activated until the entire train has passed?
#6 Posted : 13 January 2021 13:48:39(UTC)
French_Fabrice
Frankly, I've not seen such behavior.
Because when 1st time event is fired, the "state" of the block changes.
As a result, the software ignores other same event for Enter sensor related to other axles firing the event.
For "In" sensor (arriving), the additional event for same sensor are also ignored, and for departing from the In zone, the block is freed only when the next block has its zone "In" reached. So, anything related to passing over "In" zone (departure) is ignored whatever the number of axles passing over..
That's a common misconception to think other axles will trigger an other event. In fact it depends on the state of the block.
See https://wiki.rocrail.net/doku.php?id=block-en for block status.
The only thing you have to determine is the right length of the "In" zone, in case it is just before a switch coming from another track. Most of the time, 18 or 27 cm is enough, but the Vmin speed must be low (10 or 15%) of max speed.
Fabrice
PS: For sidings tracks, you may wish to add more sensors if you want to trigger special events, some of these additional sensors may not be related to block slow down
Offline fynrfin
#7 Posted : 13 January 2021 22:20:48(UTC)
fynrfin
OK,
.....A use case with a 3rd sensor (pre2in) in the block is for some station tracks where a "short train" have to stop not at the end of the block (In location) , but at the pre2in zone (close to the station or in the middle of the platform...)
Fabrice
Thank you Fabrice,
I hope it is OK to ask a similar question in the same thread. I have some long storage tracks, which may fit two shorter train one after another. I would like sensor tracks to be long in order to catch lost cars, as the tracks are hidden.
So is such long track one block or two blocks?
Can I have just two sensors? one covering the first say 150 cm of track and another covering the next 150 cm?
Right now I had only planned for one long sensor across all 300 cm, but that will not work to park more than one train for the shorter trains, correct?
What would you suggest?
Sincerely,
Steen
Steen Jorgensen
#8 Posted : 14 January 2021 08:19:28(UTC)
French_Fabrice
Hello Steen,
I'm sorry but I don't know how to answer correctly to this question.
Maybe other forum members have some answers to provide.
However, for automation, the basic rule 1 block = 1 train must still apply. That means if you want to store 2 trains in a very long track, you need 2 blocks.
I think for occupancy detection, a 3rd "long" sensor can be used in addition to 2 short "enter" and "in" sensors, but I don't know how to handle it automatically with Rocrail.
In Rocrail, there is also a concept named "staging blocks" but I doubt it can be used in siding sections with one end "closed".
Fabrice
#9 Posted : 14 January 2021 15:52:18(UTC)
Hi Steen
Steen
With Rocrail you have multiple possibilities: one is to have multiple blocks on the same portion of track, the other is to use a "staging block"
Staging block
* allows to have variable length trains stored behind each other in the same block
* it must be a one-direction block
* it can have as many sensors to store each train behind each other very precisely
* you MUST state the length of each train and the length of the security gap you wish in between
Here is a video of a staging block
Offline Martti Mäntylä
#10 Posted : 14 January 2021 22:56:40(UTC)
Martti Mäntylä
This tutorial explains how Rocrail's "virtual blocks" can be used to implement storage tracks for variable length trains.
- Martti M.
thanks 3 users liked this useful post by Martti Mäntylä
#11 Posted : 15 January 2021 11:58:22(UTC)
Hi Martti
Thanks for the info. I use virtual blocks mostly for assembling a train (cars with loco) or separating a train.
The virtual block would have the train and the slave blocks at extremity would host the loco so that it can come back the seek the cars (the virtual block is occupied while the slave block is free).
Here is how it works
The slave block is located just past the uncoupler rail
Having also installed staging blocks I found they work very well and are more flexible with handling variable train length but:
* the traffic is slow because trains must be able to stop at the exact location
* mixing staging block and regular blocks is not so great as in random operation, the staging block is always the last to be chosen
* they work only in one direction
Offline einotuominen
#12 Posted : 29 November 2022 18:03:36(UTC)
einotuominen
Hi Martti
Hi Jean and Martti. The video Martti linked most likely explains what I need, but it's in german (as usual... Who knows, maybe I'll pick up the language some day)... So I'll just ask.
I'm building a sort of shunting-staging-classification 'ish area to a terminal siding (bumpers at the end of tracks) in order to achieve this:
1. A freight train drives to one of the tracks in the area loco first
2. A second loco drives to the area on the same track behind the freight train
3. Wagons get uncoupled from the first train
4. Wagons get coupled to the second train
There will be several tracks in the area, but let's focus on just one. Here's what I've planned so far: Just after a turnout: a short one loco length Block 1 (one sensor, enter2in) --> Normal track --> Block 2 (two sensors, enter and in) Long section of normal track --> Uncoupler track --> and right after it the sensor track for In --> Bumper.
Trains maybe variable length, so coupling the wagons to the second loco is somewhat of an issue... I'm currently thinking that maybe the tracks could have a slight incline so when uncoupling happens, the wagons would just roll down and couple with the second loco... But this would not look so nice.
How would you guys build this in Rocrail and physically and would I benefit from having uncoupler track at the short BK1 also for coupling? I don't have any of the track parts yet, so I haven't been able to test anything yet.
EDIT: Also, what happens in Rocrail if a loco leaves a block, but wagons stay there? Doesn't this cause Ghost? Confused
#13 Posted : 29 November 2022 19:29:46(UTC)
Hi Eino
First 2 videos :
On uncoupling cars with Rocrail in a mashalling yard
On collecting wagons from the same yard
Then some explanations
- the receiving ends have each one large virtual block with 2 sensors (Enter & In) and a short slave block with one sensor (Enter2In), sharing the Enter sensor of the virtal one
- the decoupling is triggered by an oblique opto sensor I have made
- during the marshalling, all 3 virtual blocks are inhibited and a sensor nearby the decoupler starts an XML program starting the uncoupling, slows the loco, position the switches for the next wagon and wait for the next decoupling. When finished the blocks are enabled
- when collecting the wagons, the schedule uses only the slave blocks (because the wagons are on the IN sensor of the virtual block, but the slave blocks are free)
So it is not rocket science but about patience and contact rail adjustments
If interested I can share the xml program
PS: I have selected the cars (for good rolling properties) and adjusted the couplings so that they couple every time. No if the train departs leaving wagons, this does not create a ghost but no route can be allowed to the block with remaining wagons as long as it is occupied. BUT in this condition (can remaing in block when the block is supposed to be empty) any contact flickering will cause a ghost
Guest (4)
This page was generated in 0.407 seconds.
