Offline filip-we
#1 Posted : 31 December 2020 19:16:51(UTC)
filip-we
Hello everyone! I own an old CM800 in pretty good shape that I want to upgrade. My goal is to install a digital decoder together with a permanent magnet and a 5 pole anchor. If it goes well I might upgrade the lights to LEDs and also add lights in the rear of the loco. I'll also make sure to do the usual service as changing the brushes, the rubber rings and also the center rail pickup since it is quite worn.
The list of parts I've come up with looks like this so far:
60943 Conversion kit
7154 Traction rings
7185 Rail pickup
600300 Brushes
As a decoder I think a ESU 54610 (Lok-pilot v5) will do. I've used in another locomotive and i
t seems enough for my needs.
So far I have taken apart and serviced a handful of Märklin engines but this will be the first one I switch any parts on. Since I am familiar with both general mechanics maintenance and electronics I think I'll be able to pull it off. I'm however not sure that the parts I've found are the correct ones. I assume by the look of my motor that it is a Small Flat commutator motor, and that I therefore should use the 60943-kit. Anyone who could shed some light on this? Also, do you have any other tips or tricks when doing a project like this? :)
Happy new years and best regards,
Filip
#2 Posted : 31 December 2020 20:58:53(UTC)
Hi Filip, welcome to the forum.
It's not difficult, and the CM 800 is quite an easy Loco, but I'm just wondering why you chose that particular one?
It looks to be in quite good original condition so is it somehow special to you that you want to upgrade it?
Happy New Year. :-)
Steve
Offline MHJ87
#3 Posted : 01 January 2021 03:19:36(UTC)
MHJ87
Hello Filip
I may be able to help as I completed this upgrade myself a few weeks ago.
I upgraded the loco as it has significant sentimental value being my first loco which I received for Christmas about 1965.
The table in the CS3 manual lists the appropriate conversion motor as 60943 which is what I used. Marklin say that to do the conversion you should send it back to Marklin.
This for me was not an option as postage to Germany and Back to Australia would be more that the loco is worth so I ordered the parts. I also used the Marklin 60972 decoder.
There is one hitch to the upgrade. With the new motor they provide new screws. The heads on the screws are bigger than the old ones and when put in foul the rear wheel. My first solution was to find where to file a flat on the head o the screw so as it would not foul the wheel. See attached photo where the tip of the screwdriver is.
This went fine but when I put the screw in it was too long and when right through the casing and stopped the cogs on the other side of the loco from turning. I did not want to cut the screw for fear of burring the thread. My ultimate solution which would have overcome the need to file a flat on the head of the screw was to make a spacer that would not foul the wheel and would keep the head of the screw from fouling the wheel. This worked a treat and the Loco lives on after some 55 years.
I hope this helps
Michael
Offline MHJ87
#4 Posted : 01 January 2021 03:23:57(UTC)
MHJ87
Hi Fiilip
I forgot to mention you have the correct part numbers for the traction ring and slider.
Also the conversion motor comes with brushes.
Michael
Offline MHJ87
#5 Posted : 01 January 2021 03:40:13(UTC)
MHJ87
Hello again Filip
Reading what I have said you are probably going to ask why I did not use the original screws with the smaller heads. I tried this but they ae too short for the new motor.
Michael
Offline filip-we
#6 Posted : 01 January 2021 11:31:50(UTC)
filip-we
Hi Michael, that's quite an extensive tutorial you posted, I could not have asked for more! So I understand you didn't need to file the screw head when using a spacer? I would assume the screw would protrude even more towards the rear wheel that way, but I'm sure it will be clearer to me when I have the parts and can see for myself. Thanks for confirming the part numbers btw.
Thanks for the welcoming Steve! I wanted to try some tinkering and I have two old analog locomotives and two Delta locomotives from the early 2000s which where all possible candidates for some kind of upgrade. It felt natural to prioritize getting the analog locomotives usable with a digital system, mainly since I don't have that many locomotives in total. Thus I went with the CM800. The other analog loco is a RE800 which I'd love to upgrade at some point when I have more experience. It is such a robust design and it works so well despite it's age!
This page was generated in 0.505 seconds.
