Offline chiemgau
#1 Posted : 30 December 2020 04:51:54(UTC)
chiemgau
How do you remove the top shell of the 8803 loco? Is it just a snap fit where you hold the bottom chassis and lift the shell off? Or is there a special trick? Thanks
Offline Zme
#2 Posted : 30 December 2020 05:48:26(UTC)
Zme
Hi. Here is a diagram of this locomotive.
https://static.maerklin....e4cfda6af61434542070.pdf
Looks like the top screw needs to be removed first . If it doesn’t just fall out, Then pull down carefully on the rear wheels of the frame.
Best wishes
Dwight
Offline chiemgau
#3 Posted : 30 December 2020 06:04:36(UTC)
chiemgau
Perfect, thank you!
This page was generated in 0.422 seconds.
