Offline randallchin
#1 Posted : 19 December 2020 05:13:45(UTC)
randallchin
Hi All,
Having let my locomotives sit in storage for ten years and never having lubricated them properly in the first place, I've learned from this forum about cleaning the armature, brushes, wheels, etc. with isopropyl alchohol/lighter fluid. It has been extremely rewarding to see my trains running again and I've enjoyed the process as well.
So I bought a few "vintage" locomotives from eBay and unfortunately, my success rate in getting them running is only about 50%. It all looks so easy on youtube, but I seem to end up breaking one or both of the wires connecting the field magnet (copper coil at the rear). Am I doing something wrong or are there some tips that can help me improve my success rate?
If this is unavoidable and I need to solder the wires back:
- what soldering iron is ideal for this?
- how do you hold the locomotive, the wire and the soldering iron at the same time?
- does the copper wire need to have insulation to keep it from shorting?
Thanks for your advice.
Randall
Offline 1borna
#2 Posted : 19 December 2020 20:46:32(UTC)
1borna
Croatia
Since these are thin wires, a 20 watt soldering iron is quite sufficient. I hold the wire with tweezers against the appropriate place and with the right soldering iron, the locomotive is heavy enough not to move.
The wire has insulation on it so it does not need to be further insulated.
I recently had a locomotive under repair that had a common wire in the middle of the winding break, so I improvised a winder
You need to have a lot of patience to rewind it all and work slowly and carefully so that the insulation on the wire is not damaged
If the wire coming from the very end of the winding breaks (it is usually the right back) then it should be unwound all the way
UserPostedImageI wish you success for a happier end to this unhappy year!
thanks 6 users liked this useful post by 1borna
Offline randallchin
#3 Posted : 19 December 2020 21:48:50(UTC)
randallchin
Wow, thanks for your advice. What a task that must have been to rewind it all! Any tips on how to keep it from breaking in the first place?
Offline 1borna
#4 Posted : 19 December 2020 22:05:43(UTC)
1borna
Croatia
Hmm, you should be very careful when disassembling, if the wires are from the stator to the cover with the brushes, it is best to unsolder them before opening, and if there is enough length, the cover can only be moved to the side and removed together with the stator if necessary?
An example of a heavily soiled engine
Cleaning in Isopropanol (alcohol)
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
thanks 4 users liked this useful post by 1borna
This page was generated in 0.379 seconds.
