Offline Rwill
#1 Posted : 14 December 2020 13:51:20(UTC)
Rwill
Do yo ever have days when everything you touch on the layout goes wrong? I am having one today.. Sorted quite a few issues out but now I have a problem with my RE620 Xrail
Lights, functions etc are working but travel in either direction judders and stops after a short distance. Any guesses? Oil, grease, slider, motor brushes, a loose wire or something expensive. Visual seem OK but I know if I explore further randomly I will mess the whole thing up!
#2 Posted : 14 December 2020 16:27:44(UTC)
Here is one simple test... Take the locomotive, lift the motor bogie lightly off the rails.
Increase power to the throttle. Does the motor run smoothly or is it "juddering"?
If the motor runs smoothly, your issue is probably track/contact related.
If the motor runs roughly or intermittently, you may have in issue related to either wiring or mechanical issues inside the locomotive.
I would also recommend that in addition to testing on a digital system, that you also test the locomotive using an analog transformer.
You can also switch the model to power from catenary and then attach a wire to one of the pantographs to verify whether there is an issue between the slider and the PC Board.
To do so, you have to change the setting of a bridge on the PC Board.
Offline rbw993
#3 Posted : 15 December 2020 18:04:41(UTC)
rbw993
I have the same problem with my 37306, Zugkraft Aargau Re 4/4. I just sent it to Rick Sinclair for repair. It started to exhibit the behavior after maybe a 1/2 hour of run time.
Roger
#4 Posted : 15 December 2020 22:53:53(UTC)
I have not run my 37326 for more than a few feet. It seemed to operate within normal parameters.
Maerklin has introduced new motors for both the Re 4/4II and Re 6/6 models, but these two models have the traditional setup.
Have the models been tested in both digital and analog modes? If digital, were you using Mfx, MM or DCC?
I would be interested in hearing whether the problem also exists in analog or MM operation.
Offline Rwill
#5 Posted : 15 December 2020 23:39:49(UTC)
Rwill
So I seem to be having a better day today than yesterday.
I took the body off this lok for the first time since new (2years?) - wow its all very neat in there. A tiny drop of oil in the spots set out in the book, my old tooth brush was used with a small amount of contact cleaner to remove residue from the wheels and slider and the slider firmly positioned in place. And tried a run again first time out it did stall but then I ran it at very lower speed 20/140 for quite a few circuits - no problem up to 40/140 no problem up to 60/140 no problem - left it there for the moment then added it normal consist of long freight wagon 10 or so (about the limit for my layout) no problem! I don't tend to run this at high speed it looks far more dignified purring round the bends!
Have just tried again now this evening and it seems to be fine.
I hope this is the solution. I don't mind a little routine maintenance - and perhaps I have shown that I do not do enough. I admire many of the forum member who fill me with wonderment at the projects they take on particularly converting older loks but that is not me`. I am a fudgy fingered grumpy old sod who likes to spend hours on Scarm redesigning his layout and even more hours simply watching the trains go by and shunting till the cows come home.
thanks 2 users liked this useful post by Rwill
Offline rbw993
#6 Posted : 16 December 2020 17:16:40(UTC)
rbw993
Glad your 37206 has recovered. I was running the 37306 on mfx. I never did test with analog. After a quick check for cleanliness and free motion in the drive train I sent it back. It is still under warranty.
Roger
This page was generated in 0.393 seconds.
