#1 Posted : 18 November 2020 19:19:08(UTC)
I have made a fairly extensive web page on the use of LEDs in models, including interior train lighting.
https://cabin-layout.mixmox.com/2019/10/modelling-with-leds.html
Hopefully it is in a digestible form for anyone who is starting without any knowledge of how they work. More experienced modellers may be able to get something out of the later content too....
LED light strip schematic
thanks 17 users liked this useful post by DaleSchultz
Offline applor
#2 Posted : 18 November 2020 21:47:38(UTC)
applor
That's a lot of time and effort compiling that article Dale and very thorough - amazing job!
Offline Ross
#3 Posted : 18 November 2020 22:43:44(UTC)
Ross
Hi Dale,
Great effort on the use of LED's.
You mention component size and a correction is needed as a 0402 size is in thousands of an inch so 40 thou x 20 thou is equal to 1mm x 0.5mm size component.
The other aspect of using LED's is to consider the viewing angle of the LED and also the colour temperature (warm white, cool white) etc.
Hope the above comments help.
Ross
thanks 2 users liked this useful post by Ross
Offline davo_vespa
#4 Posted : 19 November 2020 01:34:21(UTC)
davo_vespa
Excellent article, thank you Dale.
I have been making extensive use of LED's on my layout with the dreaded flickering. I remember reading an earlier article of yours setting out the circuit for the rectifier but found the attached on EBay and they work a treat. Cheaper and easier than building yourself,
https://www.ebay.com.au/...arJS~&frcectupt=true
Happy Days, David
thanks 2 users liked this useful post by davo_vespa
#5 Posted : 19 November 2020 03:09:02(UTC)
I've been using 0402 smd leds and its a task which is sometimes pure luck to fit to locos headlights by the right polarity, unfortunately I've found if you buy a loco and it hasn't got sound with other words the loco has lesser components such as a sound decoder they leave out sometimes the high beam option, the led circuit board has the provisions for it but haven't added them to it as well the interior cab light but again the provisions are made on the main circuit board.
#6 Posted : 19 November 2020 03:39:39(UTC)
Hi Dale,
Thanks Ross! I have corrected that... any idea why 0402 is in thou and all the others are tenths of a mm ??
#7 Posted : 19 November 2020 03:48:15(UTC)
Happy Days, David
Thanks Dave,
interesting little device. I am not sure why they advertise the input to only 15V but I suspect the capacitor is only rated for 25V.
Any idea what voltage you are getting out of them when supplied with your digital current? (or are you running analog?)
If the input exceeds 17V the cap might let go....
Have you seen any that allow a higher input? (>= 20V)
What would be really nice is a rectifier + buck converter all in one.....
Offline Ross
#8 Posted : 19 November 2020 04:28:02(UTC)
Ross
Hi Dale,
Design of electronic components in the early days started with imperial measurements (USA) now there is a mix with metric size components. I always refer to the data sheets for the true size and use.
Ross
Hi Dale,
Ross
Offline davo_vespa
#9 Posted : 19 November 2020 09:23:24(UTC)
davo_vespa
Happy Days, David
Thanks Dave,
Gu’day Dale,
I have an analog layout and the light circuit is powered by a Märklin 6003 transformer. On a mixed (incandescent + LED) circuit I measured the in/out voltage of the rectifier with my Fluke multimeter at 17.15V AC / 22.5V DC.
I purchased the 6V-16V model (they also have a 6V-32V model) and whilst on the high side, it seems to work fine with my mixture of incandescent, LED strip and SMD 0603’s.
Cost me AUD 14.86 for 10 delivered.....bargain BigGrin
Happy Days, David
thanks 1 user liked this useful post by davo_vespa
#10 Posted : 20 November 2020 13:48:59(UTC)
Hi Dale,
They are all quoted in two sizes, metric and imperial, so a 1206 component in imperial is a 3216 in metric.
See https://olimex.wordpress.com/201...tric-imperial-confusion/ for a conversion table. it gets confusing when there is an 0402 metric size and also an 0402 imperial size.
And also be aware that 0402 components and smaller are considered a health hazard, and a face mask should be worn, as it is far too easy to breath in one of them resulting in asbestosis type symptoms (miners lung, et al).
#11 Posted : 20 November 2020 14:35:27(UTC)
A digital track voltage up to 24 V should be no problem for a 25 V capacitor. But a Märklin transformer with 16 V AC nominal voltage could be a problem. And the reversing voltage will be far beyond the specification.
any idea why 0402 is in thou and all the others are tenths of a mm?
I used many 0603 to replace the factory-installed yellow LEDs in Märklin locos - and those are imperial units, too.
Offline mario54i
#12 Posted : 20 November 2020 15:45:57(UTC)
mario54i
There are millions of components with imperial size, not just 0402 LEDs.
In electronics I've always heard of mils for 1/1000 of inch, not thou. Most ICs have 100 mils or 50 mils pitch.
Metric size is relatively recent.
#13 Posted : 20 November 2020 16:50:34(UTC)
Metric sizes have been around a long time - many Japanese connectors are 2.5mm pitch, not 2.54mm (0.1") which mucks things up on large connectors. You get away with it on small connectors where hole sizes are large enough to soak up the 0.04mm per pin difference.
While mils have routinely been used as an alternative to thousandths of an inch in many countries, there are also engineers in countries that use both imperial and metric units that use mils to mean millimeters - and I have had situations where it is NOT obvious through context if they mean metric or imperial units, and that includes talking with people from any North American country.
And as to ICs, most fine pitch ones use metric units for the pin pitch, the SO- series SMD packages are the smallest that I can think of with imperial based pin pitch of 0.05". There are a lot of ICs like those used in phones which are 0.5mm or 0.4mm pin pitch.
This page was generated in 0.752 seconds.
