Offline nzrabbitty
#1 Posted : 06 October 2020 06:05:52(UTC)
nzrabbitty
I am using M track and are using Scarm software to design the layout.
I am trying to work out the minimum safe distance
from track centre to the edge of the baseboard M track
I like to have as much layout in the limited space I have
Hoping some one can an an old fella with this.
I Have found A Cheap and safe way to Have an Exciting Life
Get Married And Give your Wife A Hard Time
You Know Your Going To Get A Thick Ear
BUT you never know When
Chris
thanks 1 user liked this useful post by nzrabbitty
Offline Gregor
#2 Posted : 06 October 2020 07:58:39(UTC)
Gregor
There is no fixed rule, but jou can install side boards when you feel uncomfortable.
Gregor
thanks 2 users liked this useful post by Gregor
#3 Posted : 06 October 2020 13:21:31(UTC)
Hi Chris
The safe space near a curved track depends on the radius and on the coach maximum length.
For small typical curves (R1 , R2) there should be a distance of 38.5 mm (77mm divided by 2) or 18.5 mm away from the rail base.
The easy tracing could be made using a large washer as used in body shops for cars.
As a protection to avoid locos to fall down in case of derailment, I use a strip of transparent flexible plastic material about 35 mm high to be stapled on the 10 mm plywood used for track support.
This quick and never I had a train falling down
Offline Copenhagen
#4 Posted : 06 October 2020 13:43:55(UTC)
Copenhagen
Also be aware that Scarm may not show the correct size of the track on your computer layout. The track is probably a bit wider in real life than it shows in Scarm. That's my experience with C tracks.
Offline nzrabbitty
#5 Posted : 06 October 2020 21:22:44(UTC)
nzrabbitty
Thanks for the advice.
I use Scarm centre line for distances as the track width varies dependent on the zoom level.
I like the Clear rail around the edge, more for me than children.
I have problems with the nerve system and sometimes body control a little difficult.
Never thought of using the track spacing as my guide.
Some times the answer to the question is right under the nose.
Chris
Offline dominator
#6 Posted : 09 October 2020 11:07:46(UTC)
dominator
I found 10 mm between track and edge of base was enough. i never had a problem with exposed edges until about 6 weeks ago when "Miss Hyde" [ Holly the cat ] decided to drag a lighted coach train off the side. I now have a 100mm high wall around the edges that I cant get to in a hurry.
Dereck
#7 Posted : 09 October 2020 13:11:42(UTC)
Hi y'all
As a teen I experienced the sorrow of having a whole train going down on the concrete of my father's cellar.
So since I install some sort of barrier (a transparent Rhodoïd-like strip protruding by 25 mm above the table top).
If that barrier is installed too close from the track then, in curves, long coaches will rub on it so for smaller curves a distance of 3.8 cm is advisable from track center to the edge.
Offline Gregor
#8 Posted : 09 October 2020 14:37:05(UTC)
Gregor
Top of Helix @ 1.80 meter + no safety board =
thanks 1 user liked this useful post by Gregor
Offline Jimmy Thompson
#9 Posted : 12 October 2020 00:35:54(UTC)
Jimmy Thompson
Gregor,
Crying Crying We really need to have a heart-to-heart talk with that Newton fellow about his "Gravity Thing"...
Jimmy T
Dr Dirt's Rule #1 and
#10 Posted : 12 October 2020 02:03:49(UTC)
Jimmy
You are very funny but when it happened to me and to Gregor also I am sure it was sadness and anger at not having some protection
Offline dominator
#11 Posted : 12 October 2020 06:04:59(UTC)
dominator
Years ago I set up some track on the kitchen table. I was showing a friend my mint condition 3021 when I must have turned the speed knob to full. Next minute he had to put his hand out and catch it as it flew off the table . Whew! that was lucky.
Our cat hasn't yet pulled a locomotive off and not likely to now.
Dereck
This page was generated in 0.698 seconds.
