Offline carlostau
#1 Posted : 02 September 2020 22:53:12(UTC)
carlostau
Argentina
Hi All.
I have been tinkering with the old 7051 crane. So far I have developed a simple joystick control with arduino to rotate the crane and lift the hook, but I wanted to know if anyone has developed some mod for the boom so it can also be controlled.
I did a search but could not find anything specific.
This is an analog layout with the classic 20v crane.
Thanks!
#2 Posted : 02 September 2020 23:53:18(UTC)
Originally Posted by: carlostau Go to Quoted Post
Hi All.
Thanks!
Speaking off the top of my memory, I am pretty sure I have seen such an article in an OLD issue of Märklin Magazine!
I can try to look for it, but I have so many of them, that there aren't any guarantee...
Mechanically it was quite complicated, using a lot of gears and axles. (you will need another crane as donator...)
Offline carlostau
#3 Posted : 19 September 2020 00:32:18(UTC)
carlostau
Argentina
Hi All.
Thanks!
Thanks. Yes, it is quite complicated. Since mi crane operates within a 120 degree radius, I think I will use a servo or a dc motor to operate the angle.
thanks 1 user liked this useful post by carlostau
#4 Posted : 19 September 2020 06:58:34(UTC)
This is how it is done with the Marklin Metall version of this crane....
The spiral gear drives the round brass gear wheel which is attached to the large blue wheel. The blue wheel has a long axle attached to it which when wound forwards lowers the boom and when wound backwards raise the boom. Maybe you could swipe some Marklin Metall parts for your conversion, but they may be a bit too large for the 7051 crane.
Hope this is of use.
At the point where the axle is joined to the boom, there is a swivel joint to allow for moment.
#5 Posted : 19 September 2020 10:34:57(UTC)
Hi Carlos
Here is my 7051 inside
I have not done the change but IMO you need to:
- modify the wiring and install a decoder in the crane (to bring digital signal in the cabin instead of the hook & light
- install a small whinch using a tiny DC motor & gears like this one
It sells for less than 4 € in places like this https://www.ebay.de/itm/GA12-N20...6fa3452eb1c8fff51816c2b0
It is 34 mm long and weights 12 g.
I think it is an interesting project
#6 Posted : 19 September 2020 12:10:15(UTC)
If you are reluctant having a decoder inside the crane cabin, you may try adding a conducting ring (and also add an additional slider in the cabin) to drive the motor with a separate supply
Here is the tower top where a new conducting ring needs to be added
Offline carlostau
#7 Posted : 19 September 2020 12:36:43(UTC)
carlostau
Argentina
Hi Jean, thanks for your input.
I did consider the motor with the reductor you mention.. it could fit. My circuit is analog so there is no need for a decoder.
One option to avoid installing the ring is to:
Use an arduino nano powered from the magnet / lamp pin (this needs a rectifier bridge and cap)
Add a nRF24L01 RF Module to make this wireless and receive the data from another arduino with the nRF24L01 RF Module.
In my case since the crane only moves within a radius od about 120 degrees total, I think I can live with the wires hanging on the side and have the control wired directly
#8 Posted : 19 September 2020 14:05:26(UTC)
Good for you
Is anything impossible with Arduino?
Offline Crazy Harry
#9 Posted : 19 September 2020 20:49:24(UTC)
Crazy Harry
I searched the topic of remotely raising and lowering the 7051 crane boom a while ago and found the following links (they are in German):
This one seems more elegant
Crane Boom Motorization
This one is more complicated and mounts the motor on top of the boom's counterweight
Crane Boom Lowering and Raising
I haven't tried either method and may never modify my crane other than using a joystick to operate it.
Harold.
thanks 3 users liked this useful post by Crazy Harry
Offline carlostau
#10 Posted : 20 September 2020 04:15:25(UTC)
carlostau
Argentina
Harold.
Thanks a lot. So far I have used a servo to move the boom. Works as expected with its inherent limitations. I am trying the dc motor next which should allow me to move the boom in a more precise way.
I will keep you posted.
#11 Posted : 20 September 2020 11:05:29(UTC)
Next step is this:
thanks 7 users liked this useful post by Purellum
This page was generated in 0.382 seconds.
