Offline Stiewie
#1 Posted : 16 September 2020 21:25:02(UTC)
Stiewie
Hi trainfans, i recently bought a starterkit with a mobilestation 2/3 (black one) from Marklin.
The problem is that it often stops working and then starts again automaticly,the display light goes off and the buttons don’t work. After about ten seconds everything is fine again.
In the meanwhile i can’ t control the trains, they keep on driving,so the power stays on apperently.
I got a new one from my dealer,but the second one has the same problem,only
Lesser times.
Anyone familiar with this problem?
Offline Bones
#2 Posted : 30 January 2021 10:05:05(UTC)
Bones
The first thing to check is that the wires from the terminal box haven't been connected the wrong way round to the track
Then if they are fine then it's possible there is a fault in the loco decoder
If you can get your dealer to test your loco for faults - If that's fine then get him to test your terminal box
It's possible though you have unfortunately come across some faulty ones
If they are less than 12 months old then you can replace them under warranty
This page was generated in 0.313 seconds.
