Offline Michael4
#1 Posted : 25 August 2020 15:30:16(UTC)
Michael4
At this time of year my mind moves to thoughts about changing my layout...
My question is:
Using M track radii of 5100 and 5200 and a helix, does a helix gain sufficient height in a single revolution to allow the use of standard M track catenary?
My locos are old and heavy, the trains are normally made up of three tinplate carriages, not much more so a steepish gradient is useable.
#2 Posted : 25 August 2020 16:45:04(UTC)
It´s a bit harsh, but vintage Märklin should be able to do it.
There are two "tricks" that you can apply;
1) Make sure that the UPgoing round is using the 5200 curves.
2) Use a cut-up N-scale flextrack as catenary, stapled to the underside of the helix floor. That will allow you to minimize height between helix levels.
#3 Posted : 25 August 2020 17:19:18(UTC)
Another trick to get a little more height between turns, or to lessen the grade, is to make the helix slightly oval. Have two or three 5106 straights each side to just extend it a bit like the Marklin C track one in the last link of TEEWolfs post over in TheWolfs thread.
Offline Michael4
#4 Posted : 25 August 2020 18:00:18(UTC)
Michael4
Thanks for the helpful suggestions. I can see the value of making it an oval but doubt I have the space.
Next question: Has anyone made drawings of the components that I could use? Cheeky I know but I'm a lazy old .....(insert as appropriate)
This page was generated in 0.255 seconds.
