Offline sharples
#1 Posted : 23 August 2020 23:56:09(UTC)
sharples
Can anyone give me guidance on how to use a set of double slip points in a layout (esp. wiring instructions)?
Is there a manual or instructions for use of these points available on-line?
I was hoping to use this method to enable trains to cross from one track to the other in a set of parallel tracks.BigGrin
Offline franciscohg
#2 Posted : 24 August 2020 02:15:07(UTC)
franciscohg
Chile
Hello
5207 is a double solenoid switch, with 2 positions available, curve and crossing.
The wiring is simple, yellow cable goes to power ( yellow in transformer for analog and center conection in a decoder, also yellow if you are using K83 )
the 2 others blue cables control each position of the switch, one for cuerve, one for crossing, they are connected to red and green in a push button device or to the other 2 connections in a decoder for digital, also red and green if you use k83.
#3 Posted : 24 August 2020 12:03:24(UTC)
5207 manual attached
5128_5207.pdf (149kb) downloaded 42 time(s).
Picture from the 1980 catalog showing use of the 5200 series of turnouts.
Offline sharples
#4 Posted : 25 August 2020 22:32:04(UTC)
sharples
Thanks for this! Exactly what I needed!
This page was generated in 0.352 seconds.
