Offline oranda
#1 Posted : 22 August 2020 16:35:28(UTC)
oranda
I suspect my V60 2910 has a kaputtt decoder.
There is no light showing when I place it on the CS3 programming track.
I doubt it is the motor but I assume if I strip out the decoder, I could apply a voltage to see if it runs.
I doubt if I can find a UK dealer who could fix it so I'd like to have a go and fix it myself.
If I wish to replace the decoder chip, where should I look to get a new chip and the necessarry instructions?
I there a particular chip/make I'd need?
#2 Posted : 22 August 2020 17:42:55(UTC)
It is impractical to replace the chips on a decoder, especially the microprocessor chip as there is no way to reprogram it.
Just what is the catalogue number of this loco?
Whereabouts in the UK are you situated?
Offline oranda
#3 Posted : 22 August 2020 18:13:57(UTC)
oranda
Hi kiwiAlan
I wasn't intending on micro surgery to the chipset, more a simple swap out and in of a compatible decoder board.
in the 29108 pdf it mentions the decoder 133 236 (which Märklin appear not to supply anymore - hardly surprising)
I'm in Milton Keynes - not a hot bed of Märklin Users so far as I can determine :-)
Offline g-gekko
#4 Posted : 22 August 2020 23:10:26(UTC)
g-gekko
The decoder is a variety of the 60760 decoder. It is not much free space in that locomotive. You might try to replace it with a 60982 if you are unable to find one identical to the one currently installed.
Leif
#5 Posted : 23 August 2020 00:31:42(UTC)
Leif
I may have an unused 60760 decoder that I could make available. I will have a look and see and work out a price.
Offline Dave Banks
#6 Posted : 23 August 2020 00:39:31(UTC)
Dave Banks
Have you checked continuity from the pick up shoe to the decoder with an ohm meter yet?
D.A.Banks
#7 Posted : 23 August 2020 08:25:28(UTC)
Did you checked if there is contact between pick up shoe to the decoder by call contact?
#8 Posted : 23 August 2020 08:29:48(UTC)
Goofy, I think Dave Banks already asked that question....!
Offline oranda
#9 Posted : 23 August 2020 13:04:03(UTC)
oranda
I'm no electrician but:
I'm getting a continuity sound from a couple of large resistors at the motor end and another couple give a reading but no sound. Touching anywhere on what I think is the decoder (sitting vertically and at right angles to the track/wheels) gives not sound or reading.
#10 Posted : 23 August 2020 18:53:08(UTC)
it´s a delta decoder and they are cheap decoder with minimal short service life.
The locomotive are fantasy model.
Never seen this model before made of Märklin.
#11 Posted : 23 August 2020 21:13:59(UTC)
Huh? It is not a Delta decoder, it is an fx decoder. While they may be made to a price this doesn't mean they will have a short service life. yet another pronouncement from someone who hasn't worked inside the electronics industry.
The model may be a 'fantasy' model, there were a small handful of these using asian manufactured chassis with oversized wheels, and fitted with the V60 body, and another steam loco with a 3000 like body. They were mentioned with this forum some years back when they were current, so you will have seen mention of them here, even if you haven't sighted a physical example.
#12 Posted : 24 August 2020 07:04:42(UTC)
Huh? It is not a Delta decoder, it is an fx decoder. if you haven't sighted a physical example.
In the manual of the locomotive it does only have one adress and it´s 72.
Fx decoder does not have this.
#13 Posted : 24 August 2020 08:21:26(UTC)
Maybe you should read the manual again................ LOL
• Recognition of the mode of operation: automatic.
• Addresses that can be set: 01 – 80
• Address set at the factory: 72
• Headlights for the locomotive. They can be turned on and off
in digital operation
• Adjustable acceleration/braking delay.
• Adjustable maximum speed.
• Setting the locomotive parameters (address, acceleration/
braking delay, maximum speed): with the
Control Unit, Mobile Station, Central Station
https://static.maerklin....18e76db74f1434542086.pdf
This is clearly a FX decoder Laugh
#14 Posted : 24 August 2020 09:34:43(UTC)
Opsss...my fault.
But the decoder are probably dead.
Time to change out it?
Offline ocram63_uk
#15 Posted : 24 August 2020 15:28:13(UTC)
ocram63_uk
it looks like we are not helping out our friend here :-(
Decoder status ? Assumed dead 70 % (guessing)
Model number: 29108
Decoder to replace? Yes and probably with a DCC one for N scale.
Control unit used? CS3
So you can install a multi protocol decoder without problems, any brand is fine.
HTH
Offline ocram63_uk
#16 Posted : 24 August 2020 15:32:06(UTC)
ocram63_uk
Out of curiosity, have you checked that the decoder address and the one assigned for this loco on the CS3 are the same ?
Does the CS3 have the possibility to find the address of a decoder so that you can see if it was changed and you don't remember ?
Offline oranda
#17 Posted : 24 August 2020 16:14:23(UTC)
oranda
The thing is dead - no lights respond - nothing reacts - I've tried many id addresses as outlined here above and nothing.
I'm 90% positive it need a new decoder.
Offline oranda
#18 Posted : 24 August 2020 16:16:17(UTC)
oranda
Model number: 29108
HTH
You are helping me as you are confirming what a lot there is to know about these models as well as confirming what I tried . I'm not sure though why I might need an N scale decoder for a H0 scale loco?
Offline ocram63_uk
#19 Posted : 24 August 2020 17:33:41(UTC)
ocram63_uk
From the picture you have posted of the decoder it looks like there is little room
for an H0 decoder, but I may be wrong. Don't know the loco at all apart from the photos I've seen
online so have no idea on dimensions
#20 Posted : 24 August 2020 18:08:58(UTC)
I do have an unused 60760 decoder spare that I can supply, and I am not that far away from Milton Keynes.
The decoder dimensions are 22.5mm long (when i trim the ends of the heat shrink), and 17.5mm wide (over the heat shrink). If things are really tight then the heat shrink can be removed.
Offline oranda
#21 Posted : 25 August 2020 21:04:55(UTC)
oranda
I emailed you direct, yesterday
#22 Posted : 26 August 2020 00:37:44(UTC)
Ah, OK. Found it, it had gone to the spam folder. I'll reply tomorrow, off to bed now.
Alan
#23 Posted : 30 August 2020 20:05:11(UTC)
Well, I can confirm that the loco is working again after a 60760 decoder transplant. The 60760 decoder is the same PCB size as the original decoder, but wouldn't clip into the plastic clip because the placement of components is different, so a wee rearrangement was needed, but eventually everything was wired up properly and the body fitted.
Offline oranda
#24 Posted : 30 August 2020 22:33:39(UTC)
oranda
What a great community of users, all providing support.
Many thanks to Alan for doing open heart surgery on my V60. It was a privilege talking to and watching a truly skilled man like Alan isolate and repair my diesel locomotive. It also made me aware of just how much I would have struggled if I had attempted it myself. A real education.
thanks 4 users liked this useful post by oranda
#25 Posted : 31 August 2020 00:07:13(UTC)
Having met Alan a time or three, here, and there, I can endorse your comment. BigGrin
Meeting other members "in the flesh" is to be encouraged wherever possible.
This page was generated in 0.708 seconds.
