Offline 3864jk
#1 Posted : 15 August 2020 13:41:36(UTC)
3864jk
Some advice please:
My DCC 3 car TEE runs well on DCC but the directional lights will not change. In forward both front and rear lights are white and in the opposite direction both front and rear lights are red. Any suggestions please on how to correct this faults.
Many thanks in advance.
#2 Posted : 15 August 2020 13:51:35(UTC)
Sounds like you just need to cross 2 wires. Maybe check to see if the micro-connector between units can be turned 180º?
If it is digital DCC, there are CV´s that control this. Currently I only know a little about Uhlenbrock. The correct CV-addresses would depend on the deco you have...
Offline 3864jk
#3 Posted : 15 August 2020 18:54:32(UTC)
3864jk
Henrik,
Many thanks for the suggestion to rotate the plug connectors and it worked. Correct directional lights now in both directions with the plug up side down. It must have been fitted incorrectly at the start.
This page was generated in 0.313 seconds.
