Offline carlostau
#1 Posted : 11 July 2020 22:30:37(UTC)
carlostau
Argentina
Hello.
I am not sure if this is the right place to post this. Feel free to move it if you consider it is not.
I have been tinkering with this to see if I can create a suitable replacement of the 7072 control box for analog tracks.
Basically the operation is as follows:
1 Button with a Green led and 1 button with a red led.
Upon pressing a button. The matching led will remain lit and the other led will turn off.
Simultaneously, a relay connected to the marklin trafo circuit sends a 500ms pulse (this can be adjusted) to the solenoid of whatever is connected there
I sketched this on the arduino simulator (Circuits) that Tinkercad has and it works very well.
You will need 2 relays for each signal or turnout.
Here is the link in case you want to see it in action. Please disregard the wire mess :)
https://www.tinkercad.co...kndqK71sgfuHwmyVheA6HuzU
In case you want to give it a try, here is the code
// MARKLIN CONTROL BOX FOR ANALOG SYSTEMS //
int pinButton = 8; //Red Button
int LED = 2; //Red LED
int pinButton2 = 12; //Green Button
int LED2 = 10; //Green LED
int RelayRed = 3; // Red RELAY
int RelayGreen = 4; //Green RELAY
void setup() {
pinMode(pinButton, INPUT); //set the button pin as INPUT
pinMode(LED, OUTPUT);
pinMode(pinButton2, INPUT);
pinMode(RelayRed = 3, OUTPUT);
pinMode(RelayGreen = 4, OUTPUT);
void loop() {
int stateButton = digitalRead(pinButton);//read state red button
int stateButton2 = digitalRead(pinButton2);//read the state green button
// EVALUATES CURRENT BUTTON PRESS CONDITION
if(stateButton == 1) { //if Red Button is pressed
digitalWrite(LED, HIGH);//turns on Red LED
digitalWrite(LED2, LOW);// turns OFF Green LED
digitalWrite(RelayRed, HIGH);// sends PULSE to relay
delay(500);// 500ms pulse
digitalWrite(RelayRed, LOW);// relay OFF
else if (stateButton2 ==1)//if Green Button is pressed
digitalWrite(LED2, HIGH);//turns on Green LED
digitalWrite(LED, LOW);//turns OFF Red LED
digitalWrite(RelayGreen, HIGH);// sends PULSE to relay
digitalWrite(RelayGreen, LOW);// relay OFF
thanks 5 users liked this useful post by carlostau
#2 Posted : 12 July 2020 03:19:59(UTC)
Thanks for taking the time to contribute.
If I may, the real issue with any DIY is the interface.
You allude to relays, however this is a bit glib as the electronics associated with protecting the chip(arduino) are pretty important.
If you are deploying one of the Arduino "off the shelf" relay shields this does need to be noted, otherwise the electronics around your choice of relay and any protective electronics should be referenced/described
regarding some programming disciplines
IMHO ..
- using usage of LED and LED2 is untidy, consider LED1 and LED2
- mixing "1" / "2" with "Red" / "Green" terminology might be improved with consistency - i.e. always use 1/2 OR Grn/Red.
- 500ms pulse is functional and possibly needed for a M-Track generation solenoid, 200/250 is fine for C-Track. Have you considered using another pin to offer the variation to load at startup, rather than hardcodeing the value in the code.
- rather than "just waiting" 500ms with the dalay, one idea is to use the time to introduce a fade in/out of the LEDs
- The way you have coded the loop, should you hold the button down for longer than 500ms there will be a VERY QUICK relay OFF/ON. This may not be the best handling of the relay.
Sometimes pulsing is desirable, but the duty cycle is possibly better aimed at 50% rather than 99%. so including a finalising 200-500ms delay to prevent the VERY QUICK OFF/ON should be considered.
- One variation is to remove the "Off" command from the "Button On" tested condition and have a separate test for "Button Off".
Thus the relay would stay active as long as you hold the button down.
This is the kind of behavior that is sometimes required/desired for an uncoupling track.
- designing for 3 (or 4) aspects might be worthwhile to have a program project that may be used generically
- similarly, if there are pins available, provisioning for a both the pulse (as you have done) and another pin for persistent ON / OFF might be considered
#3 Posted : 12 July 2020 03:38:32(UTC)
good posts from both so far...
I would add that if you use an ESP8266, in addition to that code, you can also get wifi access to the device in a very economical way.
I have done such a thing and can now control the lighting in my train room from software elsewhere on the network.
See https://cabin-layout.mixmox.com/2019/01/room-lighting-with-remotesign.html
I make my devices use a common interface language (RemoteSign) and have published the syntax as well as a Sequencer program that can be used to control them all.
Once you have the ability to switch turnouts and signals this way, over the network, you have the foundation of a layout digital control system!
Offline carlostau
#4 Posted : 12 July 2020 04:50:39(UTC)
carlostau
Argentina
Regarding the relays. I allude to the common arduino relay modules which contain an npn transistor to work more efficiently with the circuitry (tinkercad does not have this module, so I had to use a common relay)
IMHO ..
Of course it is untidy! this is not even a prototype.. this was a quick test to see how this worked on a virtual environment
Labeling the leds by color is the correct way. Futhermore, the proper way would be to label them as LedGreen01, LedRed01, LedGreen02, etc etc.
This is aimed at M tracks, not C tracks.
Yes that could work for uncoupling where you would release the button when appropriate.
Thanks for all the tips. Please feel free to edit the code to add the suggestions you mention. I was considering buying one of these 16 relay modules which should take care of most of the signals and turnouts on my layout which is very small.
Offline carlostau
#5 Posted : 12 July 2020 04:53:29(UTC)
carlostau
Argentina
Very nice indeed! Wifi would be a nice addition. I will make the tests and check the correct operation and maybe give it a shot.
thanks 1 user liked this useful post by carlostau
Offline carlostau
#6 Posted : 14 July 2020 00:25:14(UTC)
carlostau
Argentina
Quick update.
Upon preliminary tests. The program works very well and does what it is supposed to. I tested it with a switch track and a signal and both worked flawlessly.
I am using the arduino relay modules which have built in protection. Will post a video once I have it working.
Here's the updated code
const int RedButton01 = 8; //Red Button
const int RedLed01 = 2; //Red LED
const int GreenButton01 = 12; //Green Button
const int GreenLed01 = 10; //Green LED
int RelayRed01 = 3; // Red RELAY
int RelayGreen01 = 4; //Green RELAY
const int stateRedBt01 = 0; // intitialize button red
const int stateGreenBt01 = 0; // intitialize button green
void setup() {
pinMode(RedButton01, INPUT); //set the button pin as INPUT
pinMode(RedLed01, OUTPUT);
pinMode(GreenLed01, OUTPUT);
pinMode(GreenButton01, INPUT);
pinMode(RelayRed01 = 3, OUTPUT);
pinMode(RelayGreen01 = 4, OUTPUT);
digitalWrite(RedLed01, LOW);
digitalWrite(GreenLed01, LOW);
digitalWrite(RelayRed01, LOW);
digitalWrite(RelayGreen01, LOW);
void loop() {
int stateRedBt01 = digitalRead(RedButton01);//read state red button
int stateGreenBt01 = digitalRead(GreenButton01);//read the state green button
if(stateRedBt01== HIGH ) { //if Red Button is pressed
digitalWrite(RedLed01, HIGH);//turns on Red LED
digitalWrite(GreenLed01, LOW);// turns OFF Green LED
digitalWrite(RelayRed01, HIGH);// sends PULSE to relay
delay(50);// 50ms pulse
digitalWrite(RelayRed01, LOW);// relay OFF
if (stateGreenBt01 == HIGH)//if Green Button is pressed
digitalWrite(RedLed01, LOW);//turns OFF Red LED
digitalWrite(GreenLed01, HIGH);//turns on Green LED
digitalWrite(RelayGreen01, HIGH);// sends PULSE to relay
digitalWrite(RelayGreen01, LOW);// relay OFF
#7 Posted : 14 July 2020 18:34:50(UTC)
I think you will need some debounce for the push buttons.
When it goes from say, off to on, what typically happens is off off off on off on off on on on on
Debounce code will check that the new state has been that way for some ms before deciding that is really is a new state.
Offline carlostau
#8 Posted : 15 July 2020 01:12:37(UTC)
carlostau
Argentina
Thanks for the feedback.
Yes, I though so too, but it seems that does not affect it.
I must have done about 100 tests with 0 issues on signals, uncoupling and switch tracks.
The way it is coded allows you to push the button, which gives a 50ms "open" relay condition, but if you keep it pushed, the relay will remain open which is useful for uncoupling.
I received today a 16 relay board for arduino which should take care of 8 devices.
So far, so good.
Thanks again for your insights.
#9 Posted : 15 July 2020 02:40:01(UTC)
sounds good, nothing like a real test! However, you may not be detecting (by hearing) the bounce and it may be cycling the relay rapidly without you hearing it. You may also happen to be using excellent switches.
An easy way to see if you are getting bounce would be drop in some Serial.println() statements and see how many you get each time you press the buttons.
I keep an array of my input sensors, and the time of last use. I handle the debounce like this:
Code:
// sensor stuff
void checkSensors(){ // check each sensor from 1 to SensorCount
	int state;
	const byte debounce = 90; // ms
	for (byte i=1;i<=SensorCount; ++i) {
		pinMode(SensorPin[i],INPUT_PULLUP); // do this in case another command set it to OUTPUT....
		state = digitalRead(SensorPin[i]);
		if (state != SensorState[i] &&  millis() - SensorLastTime[i] > debounce) {  // it changed for debounce period
			SensorLastTime[i] = millis();
			if (state==HIGH) {
				//some stuff
			}else{
				//other stuff
			SensorState[i] = state; //keep the new value
		} // changed
	} // for each sensor
Offline carlostau
#10 Posted : 15 July 2020 03:25:32(UTC)
carlostau
Argentina
Code:
// sensor stuff
	int state;
			if (state==HIGH) {
				//some stuff
			}else{
				//other stuff
		} // changed
Thanks Dale. I will try to implement it on my program
This page was generated in 0.325 seconds.
