Offline anthpao
#1 Posted : 07 July 2020 11:12:00(UTC)
anthpao
Does anybody know how to order the end skirts (part that fills the gap when you remove the couplers) of the SBB Re 4/4 locomotives. In the manual there is no part number? Thank you.
Offline Unholz
#2 Posted : 07 July 2020 12:31:15(UTC)
Unholz
It is probably this part with the strange name Verkleidung (others would call it a Füllstück in German language):
https://www.maerklinshop...906/verkleidung-2-stueck
Offline anthpao
#3 Posted : 13 July 2020 18:32:57(UTC)
anthpao
Thank you for your quick response. The problem is that I want end skirts for Ae610 locomotive and I thought that from Re 4/4 loco would fit but I was wrong. Does anybody found any solution for filling the gap if you remove the coupler from a Ae 610 loco?
Offline Unholz
#4 Posted : 13 July 2020 22:42:26(UTC)
Unholz
For the Ae 6/6 / Ae 610 the solution is not so easy, because I think only the Schienenräumer with coupler gap is available (part number either 105088 or 277750).
This page was generated in 0.215 seconds.
