Offline pclancy
#1 Posted : 05 July 2020 15:55:07(UTC)
pclancy
What's the best Marklin (or other) pillar system to elevate CURVED C track? I'm finding that the Marklin pillars that I use for straight sections (7252) don't work well. They don't snap on. Looks cheesy.
When using the 7252 pillars, are you supposed to use screws to anchor them down to the table? Can you glue the little sections together instead?
To make C track work on the Marklin 7268 straight ramp (made for K and M track), I read somewhere that you need to file aways the edges of the c track to make them narrower. What's the best way to do that so as to not screw up the track? A file of some sort?
Does C track work on the Arch Bridge 7263 which is made for M and K track. How best to make it fit? Right now I am using M track for my bridges.
Any other tips for a C track guy who's into endless bridges and trestles?
Thanks again for your accumulated wisdom. You guys are the best!
Offline aos
#2 Posted : 06 July 2020 11:29:27(UTC)
aos
Hi there,
Take a look at the following links. Post 3 of: https://www.marklin-user...rum/posts/t43440-Bridges
Take a look also at: https://www.screwfix.com...ner-file-1-5-8-x-2/86001
Regards, Alan
This page was generated in 0.426 seconds.
