#1 Posted: : 25 June 2020 13:05:24(UTC)
Are you still painting your rails in rusty brown?
Deutsche Bahn are painting some rails white to reduce the heat-up in Summer. Currently this is a local test. And now the hot days have come and they can see if the paint makes a difference.
German news article:
https://www.t-online.de/...n-das-ist-der-grund.html
#2 Posted : 25 June 2020 14:18:45(UTC)
Hello Tom,Smile
Over the last 5 years or so I have noticed that some of the rails on the railway causeway to Venice seemed
to be painted white OhMyGod and I have posted some images of same on this great Users Group:
This resulted in some discussion on this forum after my post which wondered if this was to counter the effects of heatWink :
PhilipBigGrin
Offline mbarreto
#3 Posted : 26 June 2020 11:40:22(UTC)
mbarreto
It is more interesting to find a way to transform that heat energy in some useful energy rather than reflect it out. I don't know if there is some practical way of doing it and probably if it was easy and profitable it was already in test or production.
Miguel
Mostly Märklin H0.
#4 Posted : 26 June 2020 14:22:23(UTC)
its hard to believe that this works.
A black object radiates and absorbs heat faster, so painting the sides of the rail white is going to slow the rate at which heat radiates from it. The sides are not perpendicular to the sun's rays, so I would expect a net increase in temperature by painting the sides white.
Offline mbarreto
#5 Posted : 26 June 2020 15:04:45(UTC)
mbarreto
They need to use kind of a Goretex paint. Just it needs to work for sun radiation instead work for breath ;)
Miguel
Mostly Märklin H0.
#6 Posted : 26 June 2020 20:05:16(UTC)
But surely half the problem is the rails absorbing heat, so the white will slow down the absorption, which will mean they don't reach the same temperature during the day, and hence the rail expansion will be lower.
Offline bph
#7 Posted : 27 June 2020 00:05:23(UTC)
it will certainly help a bit. And it will be a boring, but safe job..........
as a side note, most ship superstructure are white, to reflect as much light/heat as possible
#8 Posted : 27 June 2020 04:51:35(UTC)
It works well on wind turbines BigGrin
25 - 30 years ago, the first wind turbines were grey, because they were galvanized.
In Scandinavia, this was not a problem; but when the first turbines were installed in Texas, the grey towers got so hot that it
was hard to work inside; even though the heat-producing parts like the generator etc. is above the tower, in the nacelle.
Painting them white reduced the average temperature in the towers with more than 10 degrees Celsius.
This is what I was told; apparently there are a few reasons more: https://interestingengin...posite%20rotor%20blades.
#9 Posted : 27 June 2020 06:49:53(UTC)
Thanks Per for : https://interestingengin...posite%20rotor%20blades. - I really liked the underview of the Spitfire ThumpUp
#10 Posted : 27 June 2020 10:24:20(UTC)
Loco drivers complained about the white rails, you can't see them in winter time when the tracks are covered with snow and therefore you don't know where you going
#11 Posted : 27 June 2020 11:51:40(UTC)
LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL
Offline dominator
#12 Posted : 27 June 2020 13:11:31(UTC)
dominator
Sorry to side track. During WW2, an RAF person was sitting at an airfield when a civilian plane took off. He watched it for a while, looked down, then found it hard to see it again. He made inquiries and found out it was painted a pale green. Thats why WW2 British aircraft most often were painted pale green underneath.
Interestingly, the lightened spitfires [ no armaments etc to help them go faster ] used for spying, were painted pink, so they could not be seen coming out of the sun. They used these apparently to track coastal installations deemed dangerous to the allies, and the flew very low over the sea and coast taking pictures.
Cant remember where I read about that.
With the modern technique of welding rails together, there was now no ability to absorb expansion [ talked about in the films mentioned by ShannonN ] that I could work out.
Dereck
Couldn't resist when spitfires were mentioned. But I did get back on track.Flapper Flapper
Northland. NZ
thanks 2 users liked this useful post by dominator
#13 Posted : 27 June 2020 13:43:25(UTC)
I understood they were painted sky blue like the picture above in this thread so they were less easily seen against the sky. But the bigger problem they had was they were flying so high they left vapour trails, so apparently part of the job was adjusting your height to minimise these trails as it gave those on the ground clues as to where the plane was and its heading.
There may have been others painted pink, but I haven't seen that mentioned anywhere or photos of them.
#14 Posted : 27 June 2020 14:27:37(UTC)
yes, but the sides of the rails are vertical, and the solar flux comes from above, so the effectiveness of blocking the sun's rays will be limited by the angle of incidence of the rays.
In other words the sides of the rail is not where a lot of the heat gets into the rail. Black sided rails would radiate as much as possible.
It makes sense to paint surfaces that face the sun, such as a roof.
Offline torle
#15 Posted : 27 June 2020 22:59:28(UTC)
torle
Thee Austrians are way ahead:
-=tom=-
thanks 3 users liked this useful post by torle
#16 Posted : 28 June 2020 01:30:15(UTC)
Hello Tom!
long time no hear! Glad to see you are here!
Offline Carim
#17 Posted : 28 June 2020 12:36:22(UTC)
Carim
If you can access the "BBC iPlayer", see the program "Inside Central Station", Series 1: Episode 2 at about 54:44 into the episode, you can see Network Rail painting the rails in Scotland.
Carim
#18 Posted : 28 June 2020 17:34:17(UTC)
-=tom=-
Next years Insider wagon ???
Offline Copenhagen
#19 Posted : 29 June 2020 01:47:19(UTC)
Copenhagen
The sun is never vertical above the tracks in Germany. Even if it was it would only be for a quite limited time each day. So white on the sides is still less heat.
Offline PeFu
#20 Posted : 29 June 2020 09:16:08(UTC)
PeFu
Interesting (?) facts on suncurves from the Swedish Transport Administration:
Welded rails should be laid during neutral conditions, e.g. approx. in the areas average temperature. In these conditions, rails are laid without having any tension.
Proper laid welded rails should not move at all.
On welded tracks, suncurves generally only occur
- when there are bad fastenings to the concrete sleepers or bad ballast OR
- if they are laid under non-neutral conditions OR
- in areas close to turnouts or non-welded sections.
Suncurves still occur every year even on welded tracks, mainly due to lack of funding for maintenance.
There are bigger challenges in northern Europe than in southern Europe, due to the wider span in temperatures.
MY OWN CONCLUSION: Painting the rails is a temporary solution for managing badly laid or badly maintained tracks.
Offline jerdenberg
#21 Posted : 29 June 2020 10:24:54(UTC)
jerdenberg
A difference between the sides and the top of rails that are regularly used is that the top is fairly reflective (being "polished" by the wheels of the passing trains), while the sides tend to go brown …
#22 Posted : 29 June 2020 13:33:55(UTC)
In the UK you would set a solar panel at about 55 degrees and it will get roughly even illumination at the extremes of sun altitude (i.e. longest and shortest days).
I would think that Germany would be at a similar enough angle, so painting the sides of the rails would be worth while.
Guest (5)
This page was generated in 0.688 seconds.
