Offline TEE2008
#1 Posted : 18 June 2020 13:00:11(UTC)
TEE2008
Hello everybody,
in this topic I would like to show you the beautiful Märklin 37639 V60 Postlok 4, which was a special model for the Post Museum shop.
For a long time, this beautiful ocean blue / beige V60 was the only ocean blue / beige Märklin V60 with a metal housing.
Since it didn't have an mfx decoder at the factory, I equipped it with an mLD / 3 Märklin 60972 and installed a Kugellager in the motor shield. Due to the Kugellager there is no economical oiling on this side.
The driving properties have improved significantly through this conversion.
Die V60 in der Nacht:
The outputs Aux 1 and Aux 2 must be set to "Telex" via CV 120 = 15 and CV 124 = 15.
This ensures that the output switches off after just under 3 seconds to prevent the coil from burning out.
To improve the analog driving properties, I switched off the motor control analog of the analog controller (this takes over the values ​​of the Auto-PI controller) via CV 47 = 0.
With CV 8 = 2 I was able to save the settings.
I have all the information from the additional instructions for the mLD / 3_mSD / 3.
Reprogramming is done at your own risk!
Tobias
thanks 6 users liked this useful post by TEE2008
Offline TEE2008
#2 Posted : 19 June 2020 19:38:28(UTC)
TEE2008
Hello everybody,
it would be nice to implement the orange V60 from the 2890/2690 train set with the current housing, as is installed in the 37639.
Tobias
This page was generated in 0.327 seconds.
