Offline ronsch
#1 Posted : 06 April 2020 20:58:55(UTC)
ronsch
I´m a rookie with märklin system and want to use M83 to blink at output 2. I have searched on google and this forum and here I find a thread that describe how to do. But when I test, it´s not work at all.
M83 settings is.
dip switch 1=on 2-9=off
dip switch 10=on (=dcc)
I set in CS2 pom 130.
When I touch icon at SC2-screen, the lamp just flash once but not stay flashing.
Someone that have a clue what I miss?
(reference manual I use is: http://members.ozemail.c...h%20traincontroller.pdf)
/Ronny
Offline Ross
#2 Posted : 07 April 2020 00:01:23(UTC)
Ross
Hi Ronny,
Your link didn't work for me when I tried to test it. Please try the link below.
m83 article
Link corrected 01-01-2025
For Channel 2 on the m83 you need to change the CV settings for CV118=130 and CV120=20 and since this is you first time trying to do this use the programming track not POM.
Hope this helps
Edited by user 01 January 2025 04:08:40(UTC)  | Reason: Not specified
Ross
Offline owidgie
#3 Posted : 07 April 2020 06:41:18(UTC)
owidgie
Hello Ronny, after some testing I was able to configure my m83 for light outputs on my CS3. While it is possible there is an inherent problem where the output uses track power which is not ideal.
Use of an m84 for lighting will not use track power for the output.
Rick
This page was generated in 0.274 seconds.
