Offline graafjp
#1 Posted : 12 March 2020 17:07:05(UTC)
graafjp
I would like to stock my 37775 rail car with some preiser passengers.
So I tried to open the rail car following the instructions in the manual.
I removed the buffers at the end of the rail car and the two screws at the end underneath.
Now I am able to lift the top of the railcar up but it seems to be stuck in the middle where the motor drive is located.
Any tips of owners of this rail car who tried also opening this and succeeded are highly appreciated. BigGrin
Solved:
I finally was able to get the top of the railcar.
When lifting the top (hood?) up you can try to move it a little bit to the front of the car.
And you have to bend the bottom part of the 'hood' a bit more open so the it can slide of/over the bottom part.
Perhaps you bent it also a bit open by inserting a few toothpicks between the hood and the bottom plate.
(but that was not necessary with my railcar).
Edited by user 21 April 2020 21:44:42(UTC)  | Reason: Added solution
Jos
This page was generated in 0.313 seconds.
