Offline pab-windmills
#1 Posted : 21 February 2020 00:58:03(UTC)
pab-windmills
Hey All,
I own a Märklin transfer table. It is missing several of the raised gear teeth on the table. See foto.
Does anyone have similar experience? And are you aware of any repairs that can be made to fix this?
Thx, Paul
#2 Posted : 22 February 2020 22:35:34(UTC)
Hi Paul
I have a transfer table but did not have the problem you have (I suspect few users are experiencing this).
It probably happened while inadvertently pushing the bridge while the motor was stopped. Another cause is something fell in the way of the moving bridge.
How to repair it. I would use a section of brass wire, cut and filed to be like the missing teeth. Then glue it with cyanolit type of glue while adjusting the position with a toothpick..
A stopped using mine because it is very noisy I use a 7286 turntable instead It is totally silent.
Even with the few missing teeth I suppose your transfer table works OK. Isn't it?
Märklin Transfer table (General MRR)
by mvd71 18/05/2024 12:09:24(UTC)
Märklin Transfer Table and K84 decoder (Digital)
by Timaximus 31/12/2005 20:55:34(UTC)
This page was generated in 0.189 seconds.
