Offline Gr8Viking
#1 Posted : 15 February 2020 23:05:46(UTC)
Gr8Viking
Hello All
Pulled out my Marklin trains recently after moving and set up system again.
The system is running the older M style tracks with single transformer and 66045 Delta run / control box to run 4 trains - all works great
However my question concerns purchasing a new Marklin 36821 KPF train.
I can't get the train to run, with or without the 66045 Delta box.
what am I doing wrong?? clearly would like to and be able to switch via Delta box
Thanks in advance for any input
#2 Posted : 16 February 2020 10:48:48(UTC)
Originally Posted by: Gr8Viking Go to Quoted Post
Hello All
what loco address does the manual say it has as the default address? It sounds like it is not one of the four that the delta control uses, although it should run as an AC analogue loco.
Offline Gr8Viking
#3 Posted : 16 February 2020 14:28:48(UTC)
Gr8Viking
Thank you and that's what I would have thought as well running on regular Analog mode.
The instruction manual states that factory preset is 23 and should run on Marklin transformers, Marklin Delta, Marklin Digital and Marklin Systems.
Too bad, i had looked for this model earlier prior to putting away and was pleased to find one for sale.
Guess I have to send it back.
Offline bph
#4 Posted : 16 February 2020 17:31:20(UTC)
You need to change the locomotive address to one of the 4 delta addresses. (78,72,60,24).
unfortunately i dont think it can be done with the 66045. The easiest would be if you know some one with a 6021, Mobile Station or Central Station.
Offline mvd71
#5 Posted : 16 February 2020 20:32:18(UTC)
Don't give up on your loco. You only need to find a way to change the address. There will be someone around who can help with that
This page was generated in 0.562 seconds.
