Offline Norton1972
#1 Posted : 14 February 2020 22:21:07(UTC)
Norton1972
I just acquired an MS2 and have it wired into the system. So far so good right? So I am told, via Maerklin, that there is an update available for this unit. I go to the instructions and it says to plug the MS2 into the CS2. What's a CS2? Is that the track box that the MS2 plugs into for power? Or am I supposed to do this on the internet? Or is it automatically pulled off the air waves somehow? I haven't figured out how to determine what level of update is on the unit. But I printed the instructions so have a place to start I think.
Thanks all,
Steve
#2 Posted : 14 February 2020 22:59:01(UTC)
Originally Posted by: Norton1972 Go to Quoted Post
What's a CS2?
It's a "Central Station", a much bigger unit than your MS2 BigGrin
The newer version is called CS3.
If you want the update, you either have to find a friend with a CS2 or CS3, or find a dealer that can do the update for you.
This is a CS2: https://www.maerklin.de/...te/details/article/60215
This is a CS3: https://www.maerklin.de/...te/details/article/60226
Offline PMPeter
#3 Posted : 14 February 2020 23:01:53(UTC)
PMPeter
A CS2 is a Control Station 2 which is the larger digital controller that has now been superseded by the CS3 and CS3+. Plugging in an MS2 into a CS2 is a general way of updating an MS2.
PS: I see Per has just told you the same thing.
Offline Norton1972
#4 Posted : 15 February 2020 03:42:24(UTC)
Norton1972
Thank you!!
This page was generated in 0.239 seconds.
