Offline Bertl
#1 Posted : 02 February 2020 17:24:00(UTC)
Bertl
Austria
I bought some tracks and some stuff, all Märklin, and now I have some of this things on the picture; the first one in the back is for K-tracks (7511), the one in the middle for catenary (bridge holder, 7500), but does anyone know what the one in the front is? Thanks!
#2 Posted : 02 February 2020 18:43:01(UTC)
Bottom item is a centre stud joiner for Flexi K-track when you cut your own tracks for custom curves
http://members.ozemail.c...solder_track_cutting.pdf
Offline Bertl
#3 Posted : 03 February 2020 19:24:21(UTC)
Bertl
Austria
Thank you so much!!
Offline Ross
#4 Posted : 31 December 2024 05:38:17(UTC)
Ross
Cutting and Soldering K-track
Link corrected 31-12-2024
Ross
#5 Posted : 31 December 2024 08:31:42(UTC)
H0 pieces;
The upper item is probably for mass (brown) connection on K-track.
The middle item is for supporting catenary masts on plastic bridges.
The bottom item -as already identifed, is for puko (red) connection between K-tracks. F.x. when shortening K-track pìeces. (They are shit, you should solder the middle wire bettwen tracks!)
Edited by user 31 December 2024 13:09:23(UTC)  | Reason: Not specified
#6 Posted : 31 December 2024 14:11:26(UTC)
I used that pice to join cut K track without issue. Granted, they are ona bridge and I left the sections loose on the roadbed so they can move with expansion and contraction.
This page was generated in 0.424 seconds.
