Offline springboard
#1 Posted : 26 January 2020 16:53:28(UTC)
springboard
American Samoa
Gentleman:
perhaps I'm doing something wrong other than hooking up what's explained in instructions, with the AC turntable their or two groups of wires, one group gray. red, yellow. The second group is blue wire, yellow wire and one white wire. I was able to define all wire except they say two Yellow wire, when there is obviously only one, the other being blue. i runs but does not give me contact on the other side being when the locomotive parks in the round house, it will stop looses current.
Fleischmann 665201 Gauge H0 Electrically operated turntable for 3-rail AC system
Note: Control your turntables easily – with TURN-CONTROL, the electronic
turntable control device (item No. 6915). I can use this but i'm trying not to spend the money for something i dd not think is need
Offline mbarreto
#2 Posted : 26 January 2020 20:51:50(UTC)
mbarreto
Looking at the instructions (in German that I don't know), it seems the 2 yellows refers to the blue and yellow that are "glued" together. They probably connect to the 2 rails of the bridge and so they must be shunted for operation in 3 rails mode.
The white one is the center rail of the bridge.
You can check the continuity easily with a multimeter ohmmeter or any continuity checker.
If all is well wired, maybe the spring contacts from the bridge are not ok...
Does it happens in all spoke tracks or only in few ones?
Others here know more abouth this turntable then me, so maybe they have better input to you.
Miguel
Mostly Märklin H0.
This page was generated in 0.332 seconds.
