Offline pederbc
#1 Posted : 07 January 2020 22:08:35(UTC)
pederbc
First of all, a wish of a great year to all!
My problem is this: I’m using the ESU ECoS control system and mainly the DCC protocol. I received the other day 2 of Märklin semaphore model 70412 (hp0/hp1/hp2). They can be used with Motorola, DCC and mfx. I don´t believe that the ECoS can handle mfx accessories so it’s either MM or DCC.
As it has 3 positions it will use 2 consecutive addresses. I can make the top wing work but not the lower one. I have tried selecting different signals in ECoS but can’t get it to work. Can it be that the cs2/cs3 does something that is not really DCC standard?
Have anyone in the forum been using these signals?
Many thanks in advance!
Best regards, Peder
Offline pederbc
#2 Posted : 08 January 2020 01:06:19(UTC)
pederbc
Problem solved (well, to some extent). I connected the semaphore to an MS2 and Eureka, it worked. So now what? Then I remembered reading about some other issue in the forum where the solution was to turn off Railcom. And now it works! Although I like the Railcom feature, I guess I just have to wait for an ESU fix....
Peder
This page was generated in 0.199 seconds.
