Offline John Ferguson
#1 Posted : 09 December 2019 12:18:29(UTC)
John Ferguson
I have the update 2.0 installed.
Major problem is I can’t find anyway of transferring an article to a track plan. You should be able to drag and drop but there is no way to get back to the track plan without switching the article list off.
If you edit the track plan select the add menu option only manual images are available for accessories and track items.
I imagine I am missing something. Please can I have some help.
Offline geir
#2 Posted : 09 December 2019 16:16:02(UTC)
geir
#3 Posted : 09 December 2019 18:02:06(UTC)
John Ferguson
Originally Posted by: geir Go to Quoted Post
I can see how you have moved the article window down then using drag and drop you should be able to transfer any article to the track plan.
How did you move the article window?
Offline geir
#4 Posted : 09 December 2019 18:27:08(UTC)
geir
Hi,I just used the mouce to move the window down.
In the last software version ,when you made the new article, it
automaticly pupped up in the track plan window.And when making an event,I just drag and drop from track plan window.
But in this new version ,it dont and I cant use drag and drop,so I'm stuck.
Is it a bug? maybe I need an intruction.
The instruction in the Marklin book "Running trains digitally with central station 3" Article No. 03082, is a bit out of date now.
Offline TEEWolf
#5 Posted : 12 December 2019 01:57:37(UTC)
correct so Maerklin just published a new book article #03083 "Digital control with CS3 software 2.0 and higher"
https://www.maerklin.de/...al-book-cs3-software-20/
downloads for the new book
https://www.maerklin.de/...3-software-20/downloads/
all published books
https://www.maerklin.de/...mation/maerklin-digital/
This page was generated in 0.213 seconds.
