Offline geir
#1 Posted : 07 December 2019 15:52:55(UTC)
geir
I just upgraded my cs3 to version 2.0.0
The "Edit Article list" is changed.
Some of my track contacts are messed up now.
Is it possible to get back my previous software version on cs3?
optionally where to get the previous software version
Offline TEEWolf
#2 Posted : 07 December 2019 22:22:41(UTC)
yes if you would have made a back-up before.BigGrin
Activate the bootloader update under system/settings at your CS 3. Read the handling using the internal C 3 help function.
I just realized that with the new software version CS 3 2.0.0 Maerklin changed some menues. So the bootloader update is now under system/settings/CS3/CAN.
The tickmark buttons for events are located under system/settings/CS3/Track.
Edited by user 08 December 2019 03:59:30(UTC)  | Reason: Not specified
Offline TEEWolf
#3 Posted : 10 December 2019 21:25:37(UTC)
Under the CS 3 menu "System/settings/CS3" are the buttons "save" and "restore".
I just realized the CS3 is creating back-upfiles by itself, before an update is started. There you see *.zip files from before all updates. Even I got there a file named "startconfig.zip". Of course I never restored these files because it was not necessary. But I guess by these files you may go backwards to a set up right up to as it was delivered from the manufacturer. If you want to go back to a previous software version, you may try it with one of these applicable files there as well.
Offline TEEWolf
#4 Posted : 10 December 2019 21:38:40(UTC)
double posting deleted
This page was generated in 0.401 seconds.
