#1 Posted : 11 November 2019 23:35:18(UTC)
I managed to blow a transistor on a circuit board while I was trying to diagnose a fault. It has 705 marked on the top. Any thoughts?
There is another, similar looking one, with the marking AS3.
The one in this image is not blown
Online Purellum
#2 Posted : 12 November 2019 00:20:17(UTC)
Any thoughts?
What kind of thoughts are you looking for? BigGrin
You can get the "magic smoke replacement" thoughts or just the plain "why did you do that" thoughts LOL
Most likely, and just guessing here, this is the thoughts you're looking for: https://www.ebay.com/itm...705T-705TA-/192826962090
Or these: https://www.ebay.com/sch...kw=FCX705TA&_sacat=0
P.S: Don't blow a fuse if I'm wrong LOL
#3 Posted : 12 November 2019 01:34:22(UTC)
Adrian if you make it quick I can put them onto my order, the cost is A$ 8.00 for 10 (FCX705TA), pay me later
#4 Posted : 12 November 2019 02:24:57(UTC)
He's a West Islander, who knows what thoughts they have given they are inbred convicts! Flapper
#5 Posted : 12 November 2019 03:05:51(UTC)
Does this mean his convict number is 705 ?
#6 Posted : 12 November 2019 04:06:40(UTC)
Well, we all know what thought thought
"Thought thought his feet were out of bed, so he got out to take a look"
But I'm gonna go out on a limb here and guess that "Any thoughts" means.....
1: Is it likely this component has actually failed and just needs replacing by itself?
2: Is '705' the correct code to get a replacement or is there a more suitable or substitute component I should use?
3: Is this component able to be replaced without any special tools or expertise (other than normal careful soldering)
4: Anything else I should know?
5: I'm Australian, does that help?
#7 Posted : 12 November 2019 06:11:29(UTC)
He's Australian, you got that bit right but you're assuming he actually has a thought....Flapper
#8 Posted : 12 November 2019 07:24:26(UTC)
has this been an after thought ? or was it thoughtless to inflict your thought onto others BigGrin
#9 Posted : 12 November 2019 10:16:33(UTC)
... but then ! ... Laugh
Adrian, I think you are showing a remarkable and dignified restraint in not being drawn into a response to the riff-raff !!LOL LOL LOL
Online Purellum
#10 Posted : 12 November 2019 10:53:49(UTC)
I think he's just working on his response right now, trying desperately to find a clever answer............. BigGrin Laugh LOL
#11 Posted : 12 November 2019 11:42:41(UTC)
He'll be sitting elbows at the desk, head in his hands and a kindly voice says "Are you having issues?"
"Yes Darling, Tons"
#12 Posted : 12 November 2019 11:45:08(UTC)
Most likely he's fallen asleep having quaffed a XXXX or two......(or three!)
Online Purellum
#13 Posted : 12 November 2019 12:07:52(UTC)
"Yes Darling, Tons"
U/R saw what you did there - my eyes Hertz........... LOL
#14 Posted : 12 November 2019 12:21:46(UTC)
Adrian, unfortunately the offer has expired but I always could order it on a new order.
#15 Posted : 12 November 2019 13:55:03(UTC)
Been at work.. Got home a little over 20 mins ago.. So I missed John's kind offer..
As for the rest of you.. Flapper
Online Purellum
#16 Posted : 12 November 2019 14:15:22(UTC)
That's what you get for helping an Aussie LOL
I should've posted a long list of Märklin technical tips and wire-color PDFs instead of finding the right part for you Flapper
Not the slightest offended OR offensive BigGrin
#17 Posted : 12 November 2019 15:36:25(UTC)
If the one on the image in the original post is OK why not just use that. Just a thought.
#18 Posted : 13 November 2019 02:01:33(UTC)
There is more than one of these chips on the board. I used a photo of an undamaged one to identify the one I needed to replace.Smile
Offline DTaylor91
#19 Posted : 13 November 2019 04:57:20(UTC)
DTaylor91
May I ask how the dead one met its demise?
As for unsoldering, with surface-mount electronics it is best to use a special hot-air soldering tool for this. It basically requires all four solder joints to be heated to liquid at the same time, then using something to "flick" or pull the component from the board. They do make special, tiny suction cup tools for this. Trying to remove it with a conventional soldering iron and unsoldering tools can easily damage the circuit board. Usually the solder pads will pull up with the component, and may pull up a bit of the traces as well. Not fun to repair, especially without a microscope.
As for the number on the part, on most small surface-mount components, there is an abbreviated, or much abbreviated, part number (and sometimes none at all). You will need to be VERY sure of the part number you are ordering. If you think you have the correct, full part number, I suggest looking at its data sheet to verify the abbreviated number. The data sheet will tell you specifically how that part is marked.
I hope it's not a MOSFET, because then you'll have static precautions to take as well.
As for replacing and re-soldering the part, Try using small dabs of solder paste as opposed to conventional solder. It can be dome with conventional solder, but it is not fun, and risks more damage.
Good luck!
thanks 2 users liked this useful post by DTaylor91
#20 Posted : 13 November 2019 15:42:56(UTC)
And is it an MRR related item that you have damaged?
I would agree with this. For a component like this you need either a pair of tweezers, ideally the 'normally closed tip' type or a vacuum component picker.
Again, I agree. Often the part marking has absolutely no relationship to the part number and the only way to get close to the correct part is to guess what it is likely to be and look up an appropriate data sheet to see if the marking of that part matches what you have for form. There are reverse lookup web sites but they are all rather incomplete in their listings.
Well that goes for any electronic part, not just mosfets, but junction transistors, diodes, and ICs, along with many passive components.
Good luck!
Again using a small hot air unit is good for this, although it can be easy to blow the component away.
This page was generated in 1.146 seconds.
