Offline Victor Almeida
#1 Posted : 01 November 2019 00:51:49(UTC)
Victor Almeida
I am using a small blue transformer to only power lighting and switches.
Power goes on and off.
If I use a different transformer to supply current to the same lighting and switches this does not happen.
It looks like there is a circuit breaker that cuts of power and resets itself.
Is this something that can be repaired?
Any help would be greatly appreciated.
#2 Posted : 01 November 2019 02:10:30(UTC)
Is it a classic one with metal frame or is it one of the post 1970s one with plastic housing?
My worst fear would be that the main cable has frayed and is not making contact at all times. With the metal transformers, this could lead to the mains coming into contact with the housing.
Do you have a model number on your transformer (or a photo)?
#3 Posted : 01 November 2019 13:55:25(UTC)
Blue Märklin transformers can be 16 W or 30 W. The 30 Watt ones have an indicator lamp that turns off when overloaded. The device is pretty reliable.
Two things that are problematic:
- very old transformers (1950-1955) have a rubber-like coating on the power cord which disintegrates and become dangerous
- the old voltage was 220 V and now the mains are closer to 240V so resulting reduced voltages are higher (especially the inversion voltage which can destroy some decoders).
Unless you are a trained electrician I would strongly recommend not to repair those transformers (years after your repair they may end-up in the hands of a child and harm him/her).
Notes: I opened and repaired a 30 W 280A transformer from 1951. My excuse is I am an engineer in electro-magnetic and electronic.
If, on your transformer the over-load device is failing (a bimetal contact mounted is a ceramic casing), I am sure you cannot find spares and to bypass the protection is not advisable
#4 Posted : 01 November 2019 15:02:35(UTC)
While I absolutely agree with the previous answers regarding the warnings etc., it could also just be overload.
If the "switching transformer" is smaller than the "not switching transformer", and your lights are old-fashioned bulbs,
try to reduce the power-load a little, by removing some of the bulbs Cool
#5 Posted : 01 November 2019 15:27:13(UTC)
My advice would be to buy a new and reliable and safe transformer which will last you for many years.
#6 Posted : 01 November 2019 18:17:18(UTC)
They can also be 10VA, as supplied in starter sets.
See this post for a couple of examples.
Offline 1borna
#7 Posted : 01 November 2019 19:58:32(UTC)
1borna
Croatia
I have recently been opening and repairing old transformers, the first time I changed the 230V connection
The second was probably a defective bimetal, so a short circuit caused the wire going to the slider to overheat. I changed the wire and did a short test where did the shutdown bimetal work correctly?
#8 Posted : 02 November 2019 09:43:35(UTC)
I'm surprised they still around (the old 280 model), I thought by now unless you're a qualified electrician these transformers have been all discarded.
#9 Posted : 02 November 2019 10:18:33(UTC)
I don't believe that's a 280A John! There are still plenty of them about.
#10 Posted : 02 November 2019 14:22:55(UTC)
First one is a metal case (see the tabs on the top cover) but the second one is a plastic case (again see how the top cover is molded).
#11 Posted : 02 November 2019 14:34:36(UTC)
the top one is, isn't it ?
This page was generated in 0.703 seconds.
