Offline PkMärklin
#1 Posted : 20 October 2019 13:52:55(UTC)
PkMärklin
Good afternoon,
I'm using Märklin K-rail in combination with Esu Ecos2 central station. Switches are connected to the K-83 decoders of Märklin as well.
Will it be possible to separate the power of the lamps (in other words: I would like to separate the power needed for these lamps to a separate Viessmann trafo 5200.
I tried several times, but either I make a mistake with the 'massa' / brown plug -how to connect to what?
In (my) perfect) world, it would be even nice to separate the power needed to use the switch in general: lamps including the switch itself.
But I can't get this done, as well, as the command to change the swift to re-route the train, is not working out of my Esu Ecos2 anymore.
Anyone an idea? (Clear schedule 'how to'?)
Or is art simply, not possible?
Thanks in advance!
Pk
#2 Posted : 20 October 2019 15:09:46(UTC)
Hi Pk
With recent M83 (60832) you may use a separate PSU
Re. Switch lamps you may connect them to a separate 16v power supply (AC or DC)
Offline PkMärklin
#3 Posted : 20 October 2019 15:21:28(UTC)
PkMärklin
Hi Pk
Thx. will dig into this a bit further.
Pk
This page was generated in 0.322 seconds.
