Offline Peter Pop
#1 Posted : 02 October 2019 10:20:24(UTC)
Peter Pop
Trying to connect two cs3plus. The supposed master contains all the loco and track information .connecting them with connecting cable message appears that one has to be the master the other the slave. There is no information in the book how to do this correctly
Any advice would be greatly appreciated
Offline TEEWolf
#2 Posted : 02 October 2019 21:42:22(UTC)
Did you register the CS 3 at the other one via "systems-settings"?
Also you may use the help function of the cS 3 for explanations.
See the manual at page 34 Central stations: integrating other CS controllers
https://www.maerklin.de/...NUAL_CS3_DE-EN_17-02.pdf
Märklin has also published a so called "Maerklin Erklärvideo" (explainer video). But it is German. Anyway here the link:
#3 Posted : 02 October 2019 22:07:52(UTC)
If you start on page 32 in the manual linked to you by TEEWolf, you'll find the master / slave settings described.
This page was generated in 0.230 seconds.
