Offline Jabez
#1 Posted : 25 September 2019 14:43:55(UTC)
Jabez
Most Maerklin (and other) steam locos have two or three lights at the front of the loco and the same at the back of the loco or tender.
I suspect that this is not the normal prototypical arrangement on say DB or DR locos. Does anyone know what is, or was the running light arrangement used, positions and colours?
Jabez
#2 Posted : 25 September 2019 19:24:58(UTC)
You have been a member since:: 16/02/2004(UTC)
Two or three white lights at the front is the correct configuration for DB and DR.
We have several threads about the meaning of the third light in era II in Germany.
You cannot safely assume that it is not prototypical just because Märklin does it that way. Wink
#3 Posted : 25 September 2019 20:52:22(UTC)
Jabez
#4 Posted : 26 September 2019 04:03:52(UTC)
the lights on a loco are in fact, signals.
for Trains, the designation is Zg1
Three white lights for a loco
Two if it is not a loco or control cab
Two red tail lights at the back (or one)
A shunting loco must have one white light front and rear. (Fz1)
see http://sh1.org/eisenbahn/snze.htm#TrainSig
Offline applor
#5 Posted : 26 September 2019 06:28:43(UTC)
applor
Prior to 1955 (era3a and earlier) German locomotives only had 2 head/tail lights . After then (era 3b), 3 lights was the standard.
Prior to the change to 3 running lights, the 3rd light was only illuminated as Dale advised as a signal indicating a special service.
Models from 1954 and earlier should only have 2 headlights illuminated. Since E-loks are electric the 3rd headlight was installed/fixed as opposed to a removable light.
The problem is manufacturers have often had their era3a and earlier e-loks with all 3 lights illuminated instead of 2.
Perhaps they fear ignorant customers would complain and return them because the 3rd top light is not lit, despite the fact it should not be.
My era3a e-loks I have had to modify to turn the top light off. Mainly Marklin models. The Roco E-loks have been correct with only 2 lights illuminated.
thanks 5 users liked this useful post by applor
Offline Jabez
#6 Posted : 26 September 2019 21:14:16(UTC)
Jabez
Thank you all for this 'enlightening' information.BigGrin
Jabez
This page was generated in 0.461 seconds.
