Offline stororoj
#1 Posted : 15 September 2019 04:35:31(UTC)
stororoj
Korea, Republic Of
Hello.
I have a question.
When I install more than 2 signals in my track,
the half of track lost power.
Does this happen due to the misconnections or
does the half of track require additional power?
Thank you for reading.
In addition,
I attach photoes of my tracks.
I installed a signal lamp in Track1.
If I remove track 2 or install another signal lamp in track2,
a signal lamp in track1 is not working (power off).
track1
track2
track3
track4
Edited by user 25 September 2019 05:19:27(UTC)  | Reason: Not specified
Offline PeFu
#2 Posted : 15 September 2019 10:01:32(UTC)
PeFu
I believe you need to add some more information, like article N.o. of the signal, what kind of track you have, and how you have wired everything. Then, I’m sure you will get useful feedback.
#3 Posted : 15 September 2019 11:46:22(UTC)
What system do you use on the model railway?
#4 Posted : 15 September 2019 13:16:31(UTC)
Originally Posted by: stororoj Go to Quoted Post
Hello.
I have a question.
This looks like you haven't fed power to the track between signals which you should.
So each insulated track section must be wired so that center studs ("B") are connected just before the insulated track section with the track just after the insulated track section.
Offline stororoj
#5 Posted : 15 September 2019 16:06:17(UTC)
stororoj
Korea, Republic Of
I use Marklin CS2 programming track.
Offline PMPeter
#6 Posted : 15 September 2019 17:45:33(UTC)
PMPeter
There is obviously a problem here. You should not have any signals or non-insulated connections to the programming track. Perhaps it would be a good idea if you posted a sketch of what you have connected to what.
Offline stororoj
#7 Posted : 24 September 2019 18:51:56(UTC)
stororoj
Korea, Republic Of
I attach my track photo.
track1
track2
track3
track4
Offline HO Collector
#8 Posted : 29 September 2019 17:09:10(UTC)
HO Collector
I think that you have a bad track/connection.
This page was generated in 0.379 seconds.
