Offline Peashooter177
#1 Posted : 08 September 2019 23:44:35(UTC)
Peashooter177
Hi, I'm new to this and am fitting a multi track with switch overs.
I'm trying to find information?photos on how to fit the 8954 Rail Joiner.
thanks 1 user liked this useful post by Peashooter177
Offline Carim
#2 Posted : 09 September 2019 13:31:02(UTC)
Carim
I assume that you are talking about the plastic isolating fishplates. Whilst I haven't used them myself, I think you just remove the metal fishplate from the track and substitute a plastic one for it - use one to create an isolating gap or two to create a separate electrical block (as you would do at a cross-over if both circuits are under separate electrical control). Hope that helps.
Carim
Offline Poor Skeleton
#3 Posted : 09 September 2019 21:18:10(UTC)
Poor Skeleton
As Carim says, to use these you first need to remove the metal fishplate from the rail end. Be very careful on pointwork, because it is very easy to pull the entire rail out. I know, I've done it!
I guess you can use the insulating joiners singly, but I always use them in pairs, as shown in the photo :
Use of Insulating rail joiners
Hope this is helpful, all the best
Chris
thanks 3 users liked this useful post by Poor Skeleton
Offline zscalehobo
#4 Posted : 11 September 2019 05:25:45(UTC)
zscalehobo
Trying to attach 2 images ... Remove metal joiner. Singulate the plastic joiners ..
you can leave them connected as one user above mentioned but for more realistic appearance singulate.
Make sure that if you do singulate them note the orientation. See the photos.
Frank Daniels
Owner - z.scale.hobo
A Noch "Top Dealer"
Irvine, California, USA
www.zscalehobo.com
This page was generated in 0.209 seconds.
