Offline PeFu
#1 Posted : 26 August 2019 22:44:40(UTC)
PeFu
I’m researching on bridges, as I will need three of them in addition to the Bietschtalbrücke. I decided to buy two Kibri 39720, ”Hölltobel-Viadukt”, as a test pilot for the double-track line:
These plastic bridges are pretty cheap, and can be kitbashed. However, the out-of-the-box look is very... plastic:
I re-shaped and modified the originally single-track bridge. (The valves at each end of the bridge, will be used for one of the new bridges.)
As I would like to use the same paint method for all three bridges, I wanted the paint job to be simple and easy to re-produce. Trying to find some real prototype examples from the Alps, I noticed that there generally is a significant amount of lime and light brown colors on - and around - the stones:
After some testing, this is how I’m doing this now; First, I add a basic surface of Vallejo primer:
After this, I use these acrylic paints:
When the primer is dry, I add some Burnt Umber using a sponge. I also add some stains with a sponge, using e.g. Black Ivory:
Next step is to add a ”white” wash based on Titanium White and some water. I also add very little Burnt Umber to make the paint more off-white. The mix has to be repeatedly tested and re-designed, and finally you have the right wash to add:
Note that the iPhone images don’t really justify the real object... I’m pretty happy with the final result, and I will probably use the method for the additional bridges:
thanks 30 users liked this useful post by PeFu
Offline applor
#2 Posted : 27 August 2019 07:20:55(UTC)
applor
Great job PeFu! Your technique worked very well for doing the red bricks with white mortar, I may have to try it myself for those red brick buildings.
I can't tell from your last photos but the white wash may have taken too much red out of the colour but I look forward to seeing the final photos.
#3 Posted : 27 August 2019 13:19:11(UTC)
Sorry, will try again !
#4 Posted : 27 August 2019 13:31:58(UTC)
Hello Peter,
What a fine piece of work !BigGrin
As you can see from the attached images, I am partial to bridges on my layout but none as beautifully
prototypically finished as you have shown - a magnificent effort by you !! ThumpUp
PJ
Offline PeFu
#5 Posted : 27 August 2019 18:25:06(UTC)
PeFu
Thanks applor! I believe it’s the daylight that makes the ”stained” burnt umber look more red than brown-ish on the photo. Actually, I wanted the bridge to be more grey/light brown/offwhite, as the prototype pictures above. Below, the bridge is testing its final location. Note that it’s more of a backdrop than a bridge, as I will not add an arch on the opposite side... I’m a cheater!
thanks 5 users liked this useful post by PeFu
Offline mvd71
#6 Posted : 28 August 2019 05:11:11(UTC)
Very nicely done!
#7 Posted : 25 October 2019 10:18:47(UTC)
..... Below, the bridge is testing its final location. Note that it’s more of a backdrop than a bridge, as I will not add an arch on the opposite side... I’m a cheater!
Hallo Peter,
Thanks for showing the position on the layout, with a very clever use of the single side.
Together with PJMarklins' views on his layout, it shows how bridges do make a layout interesting.
Not to mention the real-life civil engineering challenges they overcome.
This page was generated in 0.407 seconds.
