Offline Dave Banks
#1 Posted : 15 July 2019 10:28:53(UTC)
Dave Banks
Hi Guys, it's with dismay today I started to take my stored loco's out of their boxes for a test run only to find the plastic inlay "Blister" has turned a ruddy brown & is extremely brittle. I am sure you have all come across this some time or or another. My question is how does one get replacements or what other method do you use? The polystyrene in days gone by seem to hold up for a lot longer if not abused. Maybe the Australian climate has contributed to this situation.I look forward to your suggestions.
D.A.Banks
Offline MalinAC
#2 Posted : 15 July 2019 12:50:58(UTC)
MalinAC
Ireland
i once got a set on ebay which showed a good plastic insert in the pictures but when it came to me the plastic insert was in a million pieces except the heavy base part.when i run it now after a year it still leaves small bits on the track.
thanks 1 user liked this useful post by MalinAC
#3 Posted : 15 July 2019 13:04:50(UTC)
This yellowing of the plastic insert seems to be quite random. I have many of these boxes, and some are still in pristine condition after many years whereas others have gone varying shades of yellow or even brown.
The great enemy of plastic is sunlight, and I believe the worst affected of my boxes are those that have, at some point, been in shop windows. I believe that once exposed in this way the deterioration continues even after they are kept in a dark place.
Offline Dave Banks
#4 Posted : 16 July 2019 00:29:17(UTC)
Dave Banks
Hello MalinAC & Ray, many thanks for your input. I guess there is no replacing it. I will just have to improvise with other types of material.
D.A.Banks
#5 Posted : 16 July 2019 00:48:20(UTC)
Dave,
I once made a fair "cradle" for a locomotive from a few pieces of foam. You just need to make the dimensions such that the loco won't move in it's box.
Offline dickinsonj
#6 Posted : 16 July 2019 01:56:57(UTC)
Interesting theory Ray and that might explain why only a few of mine have done that. I have always wondered why just a few of them would have behaved that way, even though once in my possession they are never in direct sunlight. ThumpUp
Offline Drongo
#7 Posted : 16 July 2019 15:24:43(UTC)
Drongo
Having spent 40 years in the plastics industry, IMHO as Ray mentioned, sunlight is a killer on plastics. It's the ultraviolet light that breaks down the plastics - some plastics as affected more than others. To try and improve the life of the plastics, UV resistants are put into the plastic as it is being produced. I guess the ones that last longer have had the UV resistants and the ones that yellow definitely don't have the UV protection, and there's no way of knowing, until its too late.
Offline Elsleuth1
#8 Posted : 16 July 2019 16:06:29(UTC)
Elsleuth1
Last week I was given a gift of a Marklin 37621 set with 2 engines and a car. The box is great but the insert is almost gone however the set is beautiful and runs well.
The top piece of plastic is still in great shape. The edges of the insert are 3/8 inches thick so I ordered this to create a nice home for this set:
High Density Foam Tape, Foam Seal Strip Adhesive Weather Strip Foam Tape (19.68 feet Length(1 Inch Wide X 3/8Inch Thick), Black)
thanks 3 users liked this useful post by Elsleuth1
Offline Harryv40
#9 Posted : 16 July 2019 17:38:15(UTC)
Harryv40
Hi could I suggest Auhagen storage boxes, I had the same problem, I could not afford to buy a Marklin replacement box in the region of 25 plus euros. I looked around the internet and found the Auhagen boxes, they cost around £25 for 10 boxes.
Harry
thanks 4 users liked this useful post by Harryv40
Offline Dave Banks
#10 Posted : 17 July 2019 12:33:37(UTC)
Dave Banks
D.A.Banks
Offline Elsleuth1
#11 Posted : 18 July 2019 02:24:28(UTC)
Elsleuth1
#12 Posted : 18 July 2019 14:58:32(UTC)
Originally Posted by: Elsleuth1 Go to Quoted Post
Those vacuum formed inserts are well known for going brittle and breaking in that manner.
I haven't yet worked out a way to make new ones, but it should be easily done using a wood former, a vacuum cleaner, and warming some suitable plastic in an oven after it has been turned off.
#13 Posted : 18 July 2019 20:34:44(UTC)
Some model years had the plastic cradles that became brittle. Others had the plastic liner which could also become brittle over time. In my collection, I have the 3638 Ae 6/6 which had a brittle cradle. I was able to obtain the liner from a newer version of the Ae 6/6 and I used that to store the model. Since that time, Maerklin stopped the sale of individual liners and outer boxes.
You can still order generic outer boxes without model number, but you cannot get the liner from the factory. the only way to get one is to find a suitable model on eBay and to buy the whole box just to get the liner tray. Remember, if your original tray went brittle, chances are very high that others from the same model (model year) will have the same issue.
If you are going to resort to storing your models in a styrofoam cradle, I would recommend you find some plastic foil or a bag that can be used to hold the model, so that humidity and age does not cause the styrofoam to adhere to the model. With the recent changes in plastic recycling policies, those bags may be harder and harder to obtain. I used to use Glad brand bags, but they have moved production to Thailand and now stopped distributing them in Canada. I don't know if they are still reliable for storage.
The best way may be to pick up some high quality bubble wrap, roll up the lok and keep it some kind of case.
Eyro.ch listed some briefcase type cases for train models.
This page was generated in 0.430 seconds.
