Offline Ivan
#1 Posted : 09 July 2019 15:16:23(UTC)
Ivan
Have oiled sevearö locos and in the end found this on the floor (image in the right with dimensions).It is thin black plastic, obviously meant to prevent light dispersion.
To which loco does it belong ? Btw. it is too narriw for the back of 3312.
Thank you.
#2 Posted : 09 July 2019 17:40:55(UTC)
It belongs to the loco wich, -when put on the track at full power and lights enabled- emits light in places where it shouldnt! ;-)
#3 Posted : 10 July 2019 01:31:29(UTC)
If you can get the manuals for the 3 locos and look at the exploded parts diagram, you may be able to find that shaped part in one of the diagrams.
If you are lucky, only one has that shaped part. If you are unlucky more than one or none of the diagrams show that part.
Offline Ivan
#4 Posted : 10 July 2019 08:20:44(UTC)
Ivan
Thank you.
Unfortunately,this part is not mentioned in any diagram.There are small screens for the rear lights in locos 3109 and 3307, they are not missing, so they can be excluded.
There was a suggestion in another forum in German it could be for motor but I do not see where and how to put it in place.
Thanks again for the comment.
This page was generated in 0.248 seconds.
