Offline rrf
#1 Posted : 17 May 2019 14:22:56(UTC)
rrf
I am attempting to setup my first event using conditional logic. Per the help pages, I should be able to use the current state of a switch (a.k.a. point) as a condition within an event. Per the CS3 help page below (from code release 1.4.1), I should be able to do this.
I can pull an S88 sensor into the event and it immediately gets the magic question mark in the upper left corner that allows it to be used for conditional logic.
Yet when I pull a switch into the event and try to edit it, the condition radio button is greyed out and I cannot change it from an action into a condition. Pulling a second copy of the switch into the event as described in the help file does not help.
Has anyone figured out how to do this? If so, a description of how you were able to setup a switch state as an event condition will be greatly appreciated.
Rob
Mackenrode Wende Bahn
#2 Posted : 18 May 2019 10:14:28(UTC)
go to System->CS3 and enable "Events - Extended Mode" by checking the checkbox
Offline rrf
#3 Posted : 18 May 2019 12:35:44(UTC)
rrf
Peter, thank you so much! The learning now begins Smile
Rob
This page was generated in 0.310 seconds.
