Offline gachar001
#1 Posted : 04 May 2019 09:34:56(UTC)
gachar001
India
Hello All,
I am in the process of building a layout whose platform can be winched up to the ceiling.
What I am looking for is a safety feature where the platform can be physically locked in place with maybe 4 latches.
The winch mechanism will have a ratcheting feature which will be the primary locking mechanism that will hold it in place. But once it is winched up into it's recessed space, I want to lock it in place (maybe manually or some kind of solenoid locks) so that for whatever reason if the ratcheting mechanism slips or fails, the whole thing shouldn't come crashing down.
Any ideas you may have are welcome.
Gautham
Atlanta, GA USA
#2 Posted : 04 May 2019 10:09:13(UTC)
Hi Gautham,
is the winch manually wound by handle or is it elecctric?
Offline rhfil
#3 Posted : 04 May 2019 16:15:40(UTC)
rhfil
How far below the ceiling will it end up? Close enough for a simple hook and eye to reach it? You could even put blocks in the ceiling to reduce the distance.
Offline Tom Jessop
#4 Posted : 04 May 2019 23:58:42(UTC)
Tom Jessop
Try a big box hardware shop &look in the plumbers /pipework area for circular rubber seals used in vitreous pipework, used by plumbers as a seal at joins . Also check out in the storage area for locking devices with a flip over piece usually used on gates where a padlock can be inserted on one side . A RV shop also would have good range of device for the boxes tradies use on the back of their trucks.
Cheers Tom in Oz .
thanks 2 users liked this useful post by Tom Jessop
#5 Posted : 05 May 2019 12:46:22(UTC)
I would just phone for a joiner.
Offline gachar001
#6 Posted : 07 May 2019 13:05:48(UTC)
gachar001
India
Hi Gautham,
I am planning to put electric with limit switch on top.
Gautham
Atlanta, GA USA
Offline gachar001
#7 Posted : 07 May 2019 13:07:47(UTC)
gachar001
India
The platform will be around 350mm. There will be a false ceiling made of plywood surrounding it. The platform will sit flush with the false ceiling when it is fully up. The height of false ceiling is 350mm.
Gautham
Atlanta, GA USA
Offline gachar001
#8 Posted : 07 May 2019 13:09:20(UTC)
gachar001
India
Sorry. I did not understand what you meant. Can you please explain? Thanks.
Gautham
Atlanta, GA USA
Offline dickinsonj
#9 Posted : 07 May 2019 14:26:41(UTC)
In the US a joiner would be called a carpenter - we speak English of a sort but often don't understand the real thing. BigGrin
Offline rhfil
#10 Posted : 07 May 2019 15:46:43(UTC)
rhfil
What is the bottom of the layout made of? If it is wood of some and the ceiling is the same you could use simple slide bolts or if they are not solid enough for that you could frame both with wood to use the slide bolts. If the problem is the height of the ceiling, not sure what the 350mm is a dimension of, you could use hopper window hardware with a window pole to operate it: http://www.parrettwindows.com/hopper-multipoint-3/
#11 Posted : 08 May 2019 04:51:53(UTC)
Hi Gautham,
Because the underside of the lifted layout is flush with the ceiling, yes a joiner can figure out a simple strong-enough swivel bracket to keep the layout in place.
That may not look very aesthetic.
But I really believe that the electric winch will not allow the layout to fall, because in most cases they are a geared mechanism with enough resistance to achieve that.
Offline gachar001
#12 Posted : 08 May 2019 10:31:06(UTC)
gachar001
India
BigGrin
A carpenter is building the woodwork. I am having another company which manufactures motorized rolling shutters provide me with the lifting mechanism.
Gautham
Atlanta, GA USA
thanks 1 user liked this useful post by gachar001
#13 Posted : 08 May 2019 20:57:43(UTC)
Well you might be able to use the solenoid driven door latches used on front doors that can be release by an electrical signal (buzzed in) and place several of those around and recessed inside the perimeter. Then when you need to lower you first press the release button, and while its buzzing (pulled in the release pins) you activate the electric lowering mechanism until the latches are cleared. Better still, design the system to have the lowering mechanism auto-engage the buzzer latch release, and once the lowering mechanism clears them a switch shuts down the power to the buzzer latches.
Guest (5)
This page was generated in 0.403 seconds.
