Offline PeFu
#1 Posted : 24 March 2019 10:30:19(UTC)
PeFu
What is the span length (L) of the Faller 120535 Bietschtalbrücke?
Confused
Edited by user 10 April 2020 09:11:29(UTC)  | Reason: Not specified
Offline mario54i
#2 Posted : 24 March 2019 11:19:16(UTC)
mario54i
73 cm
#3 Posted : 24 March 2019 16:04:11(UTC)
Mine is 734 mm
If you have not already read my report on it at https://cabin-layout.mixmox.com/2017/01/review-faller-120535-Beitschtalbrucke.html it may be beneficial to you.
I note that dimensions are not published but more importantly:
I advise against assuming that once built, this bridge will be of exact dimensions. This may be why Faller publishes very little about the exact size. Despite extreme care to build this structure with great accuracy, it is not exactly straight and square. I suggest instead that you construct adjustable bases so that its position can be adjusted.
Offline PeFu
#4 Posted : 10 April 2020 09:21:30(UTC)
PeFu
As I’m planning on the construction behind and under the bridge, I’m now also curious on the height (H) of the bridge? Faller says 255 mm, but... Yes, I know I can ”build-and-check” myself, but I know there are great members out there, having the bridge!
Below is b.t.w. the area of the bridge. The backdrop has a ”valley” on the spot which i think I will use, this is only by luck and not by intention originally!
BigGrin
thanks 4 users liked this useful post by PeFu
#5 Posted : 10 April 2020 19:11:56(UTC)
I measured mine:
About 233mm from the bottom of the base to to upper surface of the bridge. However, I am not sure if I can see the actual bottom of the base as it is landscaped in, so I also measured from the top edge of the concrete foundation block: 184mm
Offline PeFu
#6 Posted : 10 April 2020 19:36:06(UTC)
PeFu
I measured mine:
Thanks Dale! ThumpUp
This page was generated in 0.284 seconds.
