Offline mgbeck_98
#1 Posted : 10 March 2019 08:35:07(UTC)
mgbeck_98
I want to make a 360mm span using 2 74620s without using a pillar in the middle. Is there a marklin answer to this or do I need to fashion one myself?
#2 Posted : 10 March 2019 12:10:57(UTC)
You may select the Kibri 39702 which is 38 cm long. See here https://viessmann-modell...hlbruecke-eingleisig?c=0
You may attach together two 74620 bridges with a 360 mm long C Rail straight- the only drawback is the bridge structure will look funny
This page was generated in 0.329 seconds.
