Offline federicofreundt
#1 Posted : 08 March 2019 04:52:25(UTC)
federicofreundt
Peru
I NEED THE KNOWLEDGE TO ORGANIZE THE CIRCUIT ADEQUATELLY TO MY EXPECTATIONS.
I WISH TO RUN UP TO EIGHT LOCOMOTIVES AT THE SAME TIME AND HOPE THE SIGNALS AND TURNOUTS WORK ACCORDING TO MY PLANNING.
I APPRECIATE YOUR POSSIBLE HELP.
REGARDS,
FEDERICO FREUNDT
FED
Edited by moderator 08 March 2019 21:43:46(UTC)  | Reason: Removed capitialisation in topic heading. Typing in capitals is considered to be shouting
Offline PeFu
#2 Posted : 08 March 2019 06:10:03(UTC)
PeFu
With a target of running 8 engines simultaneously, I believe the most effective solution - easy to implement, easy to use - is to (1) add proper contact tracks on the layout and (2) connect the CS3 to a computer running proper PC software such as Win-Digipet or Railroad & Co. TrainController. Of course, you also have decoders controllers controlling turnouts and signals.
With this solution, you can choose e.g. 7 engines to be controlled by the computer while 1 engine is controlled by yourself. Cool
Oh, also: Posting text in italics (big letters) only, easily derives an impression of ”screaming” the message... Blushing
thanks 2 users liked this useful post by PeFu
#3 Posted : 08 March 2019 08:54:43(UTC)
Can you please not post your posts in all capital letters! Typing in capitals is the same as SHOUTING at someone, and I'm sure we can all read your posts just as well if they are typed normally
(Thanks PeFu, I only saw your comment after I posted mine.)
#4 Posted : 08 March 2019 16:10:31(UTC)
Offline Elsleuth1
#5 Posted : 08 March 2019 16:19:57(UTC)
Elsleuth1
I would start by setting up 3 to 6 contact tracks per loop, hook them up to an S88 and use a CS2 or CS3 to keep 3 trains from colliding on a single loop. A step at a time is the best solution to what you want to accomplish.
thanks 1 user liked this useful post by Elsleuth1
This page was generated in 0.483 seconds.
